Hello,
I'm a complete beginner with Armbian and SOC board.
I've a bananapi pro board from lemaker and I've installed 6 month ago Raspbian / Jessie and domoticz and all works well until a click unfortunately on update icons of domoticz...and the problems began...no back up...new version of domoticz required buster...image buster not avalaible under raspbian for bananapro....
So I decided to install Armbian/buster_minimal
I've serial link on which I
@Myron
Is your BPi Pro reachable throu ssh? Does it boot? If you able to log in (ssh), you might append:
extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/1920x1080.bin video=HDMI-A-1:1920x1080@60
to /boot/armbianEnv,txt. I wouldn't use 8V power supply, when 5V are recommened.
