Hello Armbian team. 1st I would like to thank everyone for your great work.
I've been using a Minix TV box with Armbian 5.41 (kernel 3.14) for many years. Recently I have decide to try Mr. balbes150 build. The system works perfectly from SD, but after installing to emmc the boot process fails to load OS. I would be thankful if someone could point to the right direction.
[1] Hardware:
Minix Neo U1 ... S905, 2GB RAM / 16GB Flash. Emmc is Toshiba THGBMFG7C1LBAIL (AFAIK same as Sa
Hi all who have s905 and want to boot armbian from emmc )
I have Tronsmart Vega S96 Meta with 2Gb Ram and 8 Gb ROM (actually 7,2 Gb emmc)
Some time I used TV Box with armbian 20.08 kernel 5,9 from @balbes150 (thanks for this build)
Recently I find out there is armbian ophub with new kernels - Armbian 22.08.0-trunk Bullseye with Linux 5.15.55
I tried it and than decide to try move armbian to emmc.
I spent a few day to manualy boot from emmc. It worked out
