Hi eveyone,
I am coming from a a hint off Github here: https://github.com/armbian/documentation/issues/165. Igor was so kind and redirected me to this community.
I am struggling since beginning christmas to get my EspressoBin to latest versions out of dusty 2018 images.
Device
EspressoBin v7 DDR4 1G 1000_800Mhz
Baseline - What did I do?
- Update U-Boot according https://www.armbian.com/espressobin to devel-18.12.3
- Flashed SD-Card with
I've made some advancement in debugging "armbian-ramlog & armbian-truncate-log" complex.
Your /usr/lib/armbian/armbian-ramlog has a syntax error in the array expression
${XTRA_RSYNC_TO[@]+"${XTRA_RSYNC_TO[@]}"}
The 1st array lacks a closing } curly braces. Secondly, I can't figure out, why the same array is duplicated.
Even if you parse a variable XTRA_RSYNC_TO=(--delete) from /etc/default/armbian-ramlog, it will result in :
--delete+--delete
Another problem comes, w
