In Ubuntu 22.04 is Docker / Portiner broken then missing handles is disabled in the kernel # CONFIG_BPF_SYSCALL is not set. docker: Error response from daemon: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: process_linux.go:508: setting cgroup config for procHooks process caused: bpf_prog_query(BPF_CGROUP_DEVICE) failed: function not implemented: unknown.   Edit: It can also bein
