Hi all!
I have browsing the forum quite while but I did not a solution for my problem. I have bought the OP Zero from DX.com and it came with an expansion board which has two additional USB ports, a 3.5 mm AV socket and a built in microphone. And now I would like to use the audio socket as audio output and I want to use its microphone as well. But I headed some problems and I cannot use its audio features .
I am using this kernel: Armbian_5.24_Orangepizero_Ubuntu_xenial_dev_4.9.4
I t
M OPi Zero is now at
ARMBIAN 5.44.180510 nightly Ubuntu 16.04.4 LTS 4.14.40-sunxi
Linux orangepizero 4.14.40-sunxi #155 SMP Sat May 12 11:12:46 CEST 2018 armv7l armv7l armv7l GNU/Linux
aplay -l shows
**** List of PLAYBACK Hardware Devices ****
card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
Your .asoundrc should be in your homedirectory (mostly then edited as ~/.asoundrc ) or you could
