Hi, I've just ordered a Xu4 to use it as a desktop and I have never used armbian before. Is webgl is running fine in chromium browser? I want to run Construct 3 on it. Thanks in advance!
I installed the lib in my system, and OpenCL works. What strikes me is that you experienced a bootloop: I could understand X server not starting, but system rebooting ??
I noticed you must create a user called "odroid" before installing the package, for it to configure properly. So maybe it has something to do with the library not being configured and therefore symlinks not created.
In short, you can try to copy-paste this into a terminal:
sudo adduser --disabled-log
