The new version of 5.89.     Pay attention to the Odroid N2 in these images there is a new u-boot-2019. When running from SD card in u-boot "mmc" switch mode, the "boot.ini" script will no longer work. All settings are made only through the standard file "extlinux.conf". Current file "boot.ini" is used only when the system is started using a modified u-boot in SPI.
