Is there detailed info somewhere how to do so? Like I posted here I once prepared a new sd card with armbian, poped it in to have the system resize to full sd card storage and then restored the rsync backup. Back then I was successful restoring the backup on hummingboard. Now I tried with odroid hc2 backup via ssh. Turns out  you have to be root on the client if you pull a backup via ssh, else the files and folders user,group and permission won't be transfered.   Also after restore I c
