In the FriendlyARM thread http://www.friendlyarm.com/Forum/viewtopic.php?f=53&t=1427&p=5685#p5685
we did try to use A64 images from the Pine64 or the BananaPi M64 with the NanoPi A64.
The last times we did that with less success - OK Sytem is running but Network/Sound has to added via USB.
No suppport for the onboard devices
But today a user did wrote that - with the actual stable Pine64-image ( Armbian_5.69_Pine64_Debian_stretch_next_4.19.13 )
WiFi is us
I have two boards of nanopi-a64. after following the instructions here to enable usb and hdmi audio, i've tried also making the audio jack working (at least for audio output).
I did the inclusion of a custom board config as stated in post #1 of this thread.
Here is my patch file I add to <armbian-build-path>/patch/kernel/sunxi-dev/
I named it xxx-xxx-nanopi-a64-fix-usb-and-audio.patch so that it would be executed last on the patching stage of the build.
diff -
