Has anybody got DAS mode working using USB-C ?
Using: Armbian 20.08.21 Buster with Linux 5.8.17-rockchip64
I was not certain, I thought I read it was supported. I was hoping to use Windows 10 via USB 3.1 --> Helios64 USB-C to copy large video library.
Note; using UART via COM3 is working as expected.
Note; in windows I do remember seeing some USB error loading some USB driver; would it be related to some missing driver?int
Any succe
@slymanjojo to use DAS on LK 5.9, you would need to configure the USB-C as device mode.
In your helios64, create a file dwc3-0-device.dts contains following code
/dts-v1/;
/plugin/;
compatible = "rockchip,rk3399";
fragment@0 {
target = <&usbdrd_dwc3_0>;
__overlay__ {
dr_mode = "peripheral";
add and enable to user overlay
sudo armbian-add-overlay dwc3-0-device.dts
and reboot
Now, you can follow instruction on our wiki to e
