Welcome!   The main reason why it's disabled is that I never finished the configuration & testing part. My motivations is low to play with it     I wanted to create fw -> u-boot -> kernel loading way which cause me headaches then I simply went doing other things ...   other: - closed - poorly designed - already supported by many distributions https://wiki.debian.org/RaspberryPi
