Hello everyone,
I would like to build an image for the Rasperry Pi 1, 2 and Zero.
I could not found a download for a RPi on armbian.com. Then I saw that `rpi` is disabled in `/lib/configuration.sh`. Even when enabling it, I get an error during build, saying "[ error ] Building failed, check configuration" .
I wonder why the Raspberry Pi is not supported. Is it due to its closed hardware?
Thanks!
Supporting RPi versions other than Raspberry Pi 2 is not that simple since BCM2835 is armv6 SoC, and this arch is not officially supported by Debian, this ABI is not compatible with "normal" armhf.
So to make more or less usable OS image we need to either compile all Debian packages from scratch and make own "Armbian" package repository, or use Raspbian repository, in which case the obvious questions are - what and why?
What should be the key difference between Raspbian ("Official Debian di
