A test version of the image Armbian for TV boxes on the basis of RK3328. Tested on MVR9
http://freaktab.com/forum/tv-player-support/rockchip-based-tv-players/rk3328-devices/653167-bqeel-mvr9-rk3328-quad-core-64bit-cortex-a53-android-7-2-16gb-2-4ghz-wifi-bt4
All basic functions work. For running. Download. Unpack. To record on the SD card. Connect the SD card to TV box, connect a keyboard and mouse. To turn the power on the TV box. The system should start within 2-3 minutes. You
@caruso - i can confirm that your trust.img approach ist bringing the boot forward and the main part of u-boot is properly loaded, but for my box (2gb) sadly hangs quite early on:
U-Boot 2019.10-armbian (Nov 29 2019 - 09:50:19 +0300)
Model: Rockchip RK3328 EVB
DRAM:
looks like a memory timing issue to me ( @jernej - maybe any idea here too, although this is rockchip?). @caruso - on you website you have a file write_dd.txt in which you are writing more than
