13 -
Profile Information
Gender
Male
Bullseye not rebooting only needs poweroff
Relocated2007 replied to Relocated2007's topic in Odroid N2/N2+/HC4
That is really freaking awesome mate. I agree as it worked id suddenly stopped. I will try a few sd cards etc. Thanks for confirming that I'm not hallucinating as I was close to that. Mysteries hardware problem kind of unsolvable. It is a proof that if we mess up with AI someday it will kill us as it was just a glitch ;-). Terminator movie should be compulsory on every IT course 😉 Cheers -
Hi there, I have new HC4 (like 6 moths old) and since beginning I am struggling with reboot. I have latest Armbian Bullseye, and every time I make reboot, I need to power cycle to get it up. Is there any solution to that problem? I tried HK images, and they are rebooting but they are old so I want to be a bit modern but that is really annoying issue. Any help please? And Merry Christmas guys, thanks for the awesome distro even with that stupid problem.
Relocated2007 replied to Relocated2007's topic in Amlogic meson
Ok so I flashed Armbian Jammy and reboot worked. I did apt update, upgrade and there was kernel upgrade too, and reboot is not working, again. I tried nand-sata-install -> "Update bootloader" but that did no worked and still no reboot. Help please? -
Oh such a development, recent update and dietpi no rebooting too, jeez such a bad luck. -
I have tried DietPi and image for C4 and ... it is rebooting without issues. Oh well by by Armbian. -
Yeah I google a lot and it seems this is a bug which is coming on and off. Oh well I have found that system on eMMC can reboot but not on micro sdcard, I like Odroid products, but this is really annoying bug and they do do not bother as their distro somehow can reboot. -
Hi, I have C4 installed sdcard with bullseye from armbian website and all good first steps, change pass etc, update upgrade, no error on console and reboot from console it simple not rebooting, I need to power off all the time. I tried Jammy just for check that is worked so what is wrong with Bullseye? My armbianmonitor -u is at http://ix.io/4cyZ
That is me who opened that, fingers cross, someone find the solution.
Yeah I second it, have tried exactly the same and no sign of life after installing script: wget -O - https://github.com/OpenMediaVault-Plugin-Developers/installScript/raw/master/install | sudo bash However ofter first run of that script I had uknown error with network adapter so I did once not reboot and run the script seconf time and no errors however end message is long and indicating something is wrong with network adapter setup. Synchronizing state of proftpd.service with SysV service script with /lib/systemd/systemd-sysv-install. Executing: /lib/systemd/systemd-sysv-install disable proftpd Removing network-manager and dhcpcd5 ... Reading package lists... Done Building dependency tree... Done Reading state information... Done Package 'dhcpcd5' is not installed, so not removed Package 'network-manager' is not installed, so not removed 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Enable and start systemd-resolved ... Unblocking wifi with rfkill ... eth0 already found in database. Skipping... It is recommended to reboot and then setup the network adapter in the openmediavault web interface. root@odroidhc4:~# Maybe that will help with traubleshooting.
Thx worked well, I should work out by myself, I am a great noob. Oh well ;-0
I have installed omv and pi-hole via armbian-config and I can get web access to omv but when I try to get to pihole on my_server_ip/admin I am getting OMV screen red with software failure, as omv web interface seems on the same ip only without webport. So how to get to pi-hole web interface? Cheers
Hi there, I am just starting with Armbian, installed on odroid c2 emmc card, all seems to work, but when I tried to install software via armbian-config/softy just when I hit that I got on the screen small error: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf It is disappearing after 2-3 sec and I can install software which works (at least omv which I wanted) but it is weird to me.
