Posts
15 -
Joined
Last visited
Content Type
Forums
Store
Crowdfunding
Applications
Events
Raffles
Community Map
Posts posted by vfrolov
Hello!
How could it be? zram is full, but /var/log is empty.
I think this happened when once the log was full and I deleted a large file.
How to fix it without rebooting?
root@hms:/var# uname -a
Linux hms 4.19.20-sunxi #5.75 SMP Sat Feb 9 19:02:47 CET 2019 armv7l armv7l armv7l GNU/Linux
root@hms:/var# zramctl
NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram4 lzo 121,1M 4K 78B 12K 4 [SWAP]
/dev/zram3 lzo 121,1M 4K 78B 12K 4 [SWAP]
/dev/zram2 lzo 121,1M 4K 78B 12K 4 [SWAP]
/dev/zram1 lzo 121,1M 4K 78B 12K 4 [SWAP]
/dev/zram0 50M 43,8M 7,8M 8,7M 4 /var/logroot@hms:/var# df /var/log
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/zram0 49584 44780 1220 98% /var/log
root@hms:/var# du -k /var/log
12 /var/log/motion
4 /var/log/samba/cores/winbindd
4 /var/log/samba/cores/smbd
4 /var/log/samba/cores/nmbd
16 /var/log/samba/cores
28 /var/log/samba
4 /var/log/apache2
4 /var/log/apt
4 /var/log/unattended-upgrades
56 /var/log
all this is very encouraging. but how can a mere mortal get these sweeties
today after upgrading systemd package to the version "229-4ubuntu21.15" (on 32-bit armbian) sshd and some other system services are not started again. after downgrade systemd package to version "229-4ubuntu21.11" everything is workig
On 11/29/2018 at 9:34 PM, RenatoLorenzi said:
Now I received a update from 229-4ubuntu21.9 to 229-4ubuntu21.10 and everything worked again.
I Confirm. systemd 229-4ubuntu21.10 works again. Darkness Falls.
could anyone confirm that mew version of SYSTEMD (229-4ubuntu21.10) works well ??
7 hours ago, chocomega said:
Thank you very much for the instructions, I had the exact same issue ! My first thought was an SD card issue or even a hacker attack ! I spent the whole night trying to figure it out...
It's a shame that such update from Ubuntu breaks the system especially when ssh is my only remote access to the headless orange pi
thank you.
please tell us, what board & OS version/release have you got
8 hours ago, smuschevich said:
Hi, vfrolov, thank you very much for your answer!
In the end I decided to install Armbian Bionic - all problems have gone.
have you done upgrade after fresh install?
what version of systemd is installed now?
apt list systemd
thank you
6 hours ago, hajupiko49 said:
I ask for help!
First of all, I do not speak English and have had the translation done by google.
My hardware = orangepipcplus, my system is Armbian_5.59_Orangepipcplus_Ubuntu_xenial_default_3.4.113_desktop.
The system is loaded in the eMMC.
After a firmware update & upgrade (from armbian-config) or also sudo apt update & upgrade, it is no longer possible to connect via SSH from the WIN7 computer to the OPI. I have made several attempts. It's always the same. The connection to the network is rejected. The connection via XRDP is still possible.
What can I do to reuse the SSH connection after the update & upgrade?
Yours sincerely
hajupiko491. Use XRDP or HDMI monitor, as well as the USB keyboard and mouse
2. launch the terminal window using the mouse, or the keyboard by pressing Control+Alt+T
3. Execute commands:
sudo mkdir /var/run/sshd
sudo service sshd start
But the problem is much wider than what you have had encountered with
hi, smuschevich. sorry for inconvenience.
The basic idea is simple: return the package that worked before the updates
1. we need to find out which packages from the "SYSTEMD" family are currently installed on the computer
2. what was the previous version(s) that worked, unlike the new one
3. and finally, install packages of the correct version
The first task is performed by the command:
apt list | grep systemd | grep "\["
where:
apt list --- gives the full list of packages of your distribution
grep systemd --- selects only packages containing the word "systemd" in the name
>>: you may use the command "apt list *systemd*" instead of apt list | grep systemd
grep "\[" --- selects only packages containing special labels, for example, "[installed]"
in my case the output was:
libpam-systemd/xenial-security,xenial-updates,xenial-security,xenial-updates,now 229-4ubuntu21.9 armhf [установлен]
libsystemd0/xenial-security,xenial-updates,xenial-security,xenial-updates,now 229-4ubuntu21.9 armhf [установлен]
systemd-sysv/xenial-security,xenial-updates,xenial-security,xenial-updates,now 229-4ubuntu21.9 armhf [установлен][установлен] == [installed]
it shows that I'm interested in 4 packages: libpam-systemd, libsystemd0, systemd, systemd-sysv, - these are all of the seme version - very good!
The seccond task is performed by the command:
apt list -a systemd
systemd/xenial,xenial 229-4ubuntu4 armhfI assumed that the previous version was "229-4ubuntu4"
The third task is performed by the command:
apt-get install libpam-systemd=229-4ubuntu4 libsystemd0=229-4ubuntu4 systemd=229-4ubuntu4 systemd-sysv=229-4ubuntu4
Do not forget to pray hard during the third step! Good luck :-))
motion, apache, sshd, openvpn, fail2ban, apcupsd, smbd/nmbd, screen - everything is fine
not the biggest fish
did it!
# apt list | grep systemd |grep "["
# apt list -a systemdsystemd/xenial-security,xenial-updates,xenial-security,xenial-updates,now 229-4ubuntu21.9 armhf [установлен]
systemd/xenial,xenial 229-4ubuntu4 armhf# apt-get install libpam-systemd=229-4ubuntu4 libsystemd0=229-4ubuntu4 systemd=229-4ubuntu4 systemd-sysv=229-4ubuntu4
does anyone tried to downgrade systemd-related packages
I confirm. Same problem
/var/log on zram0
in Allwinner sunxi
Got it. Looks like a bug
lsof | grep /var/log
rsyslogd 1051 syslog 7w REG 254,0 18268 29 /var/log/syslog (deleted)
rsyslogd 1051 syslog 8w REG 254,0 0 26 /var/log/kern.log (deleted)
rsyslogd 1051 syslog 9w REG 254,0 44234481 22 /var/log/auth.log (deleted)
in:imuxso 1051 1811 syslog 7w REG 254,0 18268 29 /var/log/syslog (deleted)
in:imuxso 1051 1811 syslog 8w REG 254,0 0 26 /var/log/kern.log (deleted)
in:imuxso 1051 1811 syslog 9w REG 254,0 44234481 22 /var/log/auth.log (deleted)
in:imklog 1051 1812 syslog 7w REG 254,0 18268 29 /var/log/syslog (deleted)
in:imklog 1051 1812 syslog 8w REG 254,0 0 26 /var/log/kern.log (deleted)
in:imklog 1051 1812 syslog 9w REG 254,0 44234481 22 /var/log/auth.log (deleted)
rs:main 1051 1813 syslog 7w REG 254,0 18268 29 /var/log/syslog (deleted)
rs:main 1051 1813 syslog 8w REG 254,0 0 26 /var/log/kern.log (deleted)
rs:main 1051 1813 syslog 9w REG 254,0 44234481 22 /var/log/auth.log (deleted)
Perhaps, truncating the logs not syncronizeded properly with rsyslogd ...
File i removed not from this list.
restarting rsyslogd service solved the problem
