Hi,
I am not able to make Radxa Camera 8M to work with Armbian_24.5.3_Radxa-zero3_bookworm_vendor_6.1.43_minimal.img and Armbian_24.5.1_Radxa-zero3_noble_vendor_6.1.43.img
gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! jpegenc ! multifilesink location=/home/a2t/test.jpg
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
../libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.001604801
Setting pipeline to NULL ...
Freeing pipeline ...
root@radxa-zero3:~# v4l2-ctl -i /dev/video0 --list-formats
VIDIOC_S_INPUT: failed: Inappropriate ioctl for device
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture Multiplanar
[0]: 'UYVY' (UYVY 4:2:2)
[1]: '422P' (Planar YUV 4:2:2)
[2]: 'NV16' (Y/UV 4:2:2)
[3]: 'NV61' (Y/VU 4:2:2)
[4]: 'YM16' (Planar YUV 4:2:2 (N-C))
[5]: 'NV21' (Y/VU 4:2:0)
[6]: 'NV12' (Y/UV 4:2:0)
[7]: 'NM21' (Y/VU 4:2:0 (N-C))
[8]: 'NM12' (Y/UV 4:2:0 (N-C))
[9]: 'YU12' (Planar YUV 4:2:0)
[10]: 'YM24' (Planar YUV 4:4:4 (N-C))
root@radxa-zero3:~# v4l2-ctl --device=/dev/video0 --all
Driver Info:
Driver name : rkisp_v5
Card type : rkisp_mainpath
Bus info : platform:rkisp-vir0
Driver version : 2.4.0
Capabilities : 0x84201000
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04201000
Streaming
Extended Pix Format
Media Driver Info:
Driver name : rkisp-vir0
Model : rkisp0
Serial :
Media version : 6.1.43
Hardware revision: 0x00000000 (0)
Driver version : 6.1.43
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Pad 0x01000010 : 0: Sink
Link 0x02000011: from remote pad 0x1000004 of entity 'rkisp-isp-subdev' (Unknown V4L2 Sub-Device): Data, Enabled
Priority: 2
Format Video Capture Multiplanar:
Width/Height : 0/0
Pixel Format : ''
Field : Any
Number of planes : 0
Flags :
Colorspace : Default
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization : Default
Selection Video Capture: crop, Left 0, Top 0, Width 0, Height 0, Flags:
Selection Video Capture: crop_bounds, Left 0, Top 0, Width 800, Height 600, Flags:
Selection Video Output: crop, Left 0, Top 0, Width 0, Height 0, Flags:
Selection Video Output: crop_bounds, Left 0, Top 0, Width 800, Height 600, Flags:
What should be done to get the image
