jshc1
Profile Information
  • Gender
    Male
  1. Hey, Where can I find the latest images for the Odroid HC1 and ZeroPi? https://www.armbian.com/odroid-xu4/ https://www.armbian.com/zero-pi/ I understand that both SBCs are quite old and probably long forgotten by Armbian users, but I need a clean install on both and am looking for the latest existing images. I tried looking at https://armbian.lv.auroradev.org/archive, but it seems not everything is there. Thanks in advance for any help. PS Anyone still using these SBCs? Are there any alternatives in 2026 at reasonable prices?
  2. As they say, did you turn it off and on... he he Reboot helped, although I had only 8 days of uptime and in the meantime something caused some confusion. I speculate that it may be something related to cpu tool deprecated... or root@odroidxu4:~# apt list --upgradable Listing... Done armbian-bsp-cli-odroidxu4-current/bullseye 24.5.1 armhf [upgradable from: 23.8.1] N: There is 1 additional version. Please use the '-a' switch to see it However, using cpupower I was able to set 1.9 and 1.3Ghz, but setting it to 2.0 and 1.4 does not work even though cpupower provides such an option. I'm guessing it may be something deeper in the kernel set for this sbc?
  3. Hi The problem with Odroid HC1 is that BIG cores cannot go higher than 1.50Ghz and LITTLE cores cannot go higher than 900Mhz! Why is the CPU so throttled now? This sbc can and could work at higher clock speeds without any problems. Forcing 2Ghz and 1.50Ghz via cpupower does not help... Bullseye A 23.8.27 K 6.6.31
