marcz
18 -
I now use some uboot settings analogous to what you propose on the base of archinux configuration. But as you said value coded in uboot spi have to be changed when you update the kernel. This is the purpose of not storing kernel dependent values in the spi, but loading them from the device, like it is done in ArmbianEnv.txt or in archlinux in /boot/uEnv.txt. What I still does not understand is while the itb image, gives an error when trying to bootm from it. I agree that chaining UEFI bootloader should be a more flexible option, after updating the kernel it is very easy to do an update-grub, and let it generate the initrd and new grub code. And you don't have to touch the uboot itself. I have to learn more about uboot UEFI, before being able to try this option. I have never used the bootflows, so I have to learn. I have seen an interesting thread on the boot process in this forum in The boot process and various devices , beginning by a good summary by @ManoftheSea @bschnei you seem to have expertise in uboot, you should contribute to Armbian. Armbian is not to be despised, its strength is the maintenance of many sbc kernels that are not available in Debian or archlinux. And they have developed a build system that allow the update of so many device, a task out of reach of an individual alone.
to debug I launched the kernel with: setenv fdt_name dtb/marvell/armada-3720-espressobin.dtb setenv bootargs root=/dev/mmcblk0p1 rootwait ${console} ext4load mmc 0:1 $initrd_addr boot/uInitrd ext4load mmc 0:1 $kernel_addr_r boot/Image ext4load mmc 0:1 $fdt_addr_r boot/${fdt_name} booti $kernel_addr_r $initrd_addr $fdt_addr_r And it boots on the console, I will explore how I can set a more proper boot process.
The image contain in the boot/ directory: Marvell >> ls mmc 0:1 boot/ <DIR> 4096 . <DIR> 4096 .. <SYM> 32 Image <SYM> 28 dtb <DIR> 4096 dtb-5.15.149-current-mvebu64 38518 boot.bmp 0 .next <SYM> 32 uInitrd 1592 boot.cmd 4198770 System.map-5.15.149-current-mvebu64 95 armbianEnv.txt 1536 armbian_first_run.txt.template 1664 boot.scr 9681576 uInitrd-5.15.149-current-mvebu64 193310 config-5.15.149-current-mvebu64 21899776 vmlinuz-5.15.149-current-mvebu64 9681512 initrd.img-5.15.149-current-mvebu64 <SYM> 39 fdt.dtb 16578860 espressobin.itb and the content of armbianEnv.txt is board_version=v5 verbosity=1 rootdev=UUID=eb19bd31-6e1d-40ca-b936-d2823be614de rootfstype=ext4 The boot.cmd or boot.scr is "# Some tests to try to keep compatibility with old variables if test -z "${kernel_addr_r}"; then setenv kernel_addr_r $kernel_addr fi if test -z "${ramdisk_addr_r}"; then setenv ramdisk_addr_r $initrd_addr fi if test -z "${fdt_addr_r}"; then setenv fdt_addr_r $fdt_addr fi if test -z "${distro_bootpart}"; then setenv distro_bootpart 1 fi if test -z "${devtype}"; then setenv devtype $boot_interface fi load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}armbianEnv.txt env import -t ${scriptaddr} ${filesize} setenv bootargs "$console root=${rootdev} rootfstype=${rootfstype} rootwait loglevel=${verbosity} usb-storage.quirks=${usbstoragequirks} ${extraargs}" load $devtype ${devnum}:${distro_bootpart} $ramdisk_addr_r ${prefix}espressobin.itb bootm ${ramdisk_addr_r}#$board_version # fallback to non-FIT image if test -z "${image_name}"; then setenv image_name "Image" fi if test -z "${initrd_image}"; then setenv initrd_image "uInitrd" fi if test -z "${fdt_name}"; then if test -z "${fdtfile}"; then setenv fdt_name "dtb/marvell/armada-3720-espressobin.dtb" else setenv fdt_name "dtb/$fdtfile" fi fi load $devtype ${devnum}:$distro_bootpart $kernel_addr_r ${prefix}$image_name load $devtype ${devnum}:$distro_bootpart $ramdisk_addr_r ${prefix}$initrd_image load $devtype ${devnum}:$distro_bootpart $fdt_addr_r ${prefix}$fdt_name booti $kernel_addr_r $ramdisk_addr_r $fdt_addr_r # mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr When trying to load in memory boot.scr and source it it fails, so to locate the problem I rather walk through the script step by step. I can load espressobin.itb: Marvell>> load $devtype ${devnum}:${distro_bootpart} $ramdisk_addr_r ${prefix}espressobin.itb 16578860 bytes read in 730 ms (21.7 MiB/s) but when trying to boot: Marvell>> bootm ${ramdisk_addr_r}#$board_version Wrong Image Format for bootm command ERROR: can't get kernel image! I don't understand why I get this wrong image format. The following fallback script does not work either, everything go well until the booti command then Marvell>> booti $kernel_addr_r $ramdisk_addr_r $fdt_addr_r ## Loading init Ramdisk from Legacy Image at 08000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 9681512 Bytes = 9.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 06f00000 Booting using the fdt blob at 0x6f00000 Loading Ramdisk to 7ecf0000, end 7f62ba68 ... OK Using Device Tree in place at 0000000006f00000, end 0000000006f05d61 Starting kernel ... "Synchronous Abort" handler, esr 0x02000000
Nice to know about your fork of globalscale boot loader, I may go further deeper in your project later on. For today I have no longer access to my board, I will post tomorrow the two files. For specifying the device the ArmbianEnv.txt use an UUID, so it does not dépend of the location of the device.
@bschnei you say that you don't use the distribution, I don't know what you meant. But if you have a similar board that is running Armbian, it could help if you tell me the image version and the environment you use.
I have set this value as you told @bschnei, and it changes nothing. After examining boot.scr that is first loaded, I see that root is reset in this script so the root env value does not matter. After setting the variables like cited above, it find the script it seems to load armbianEnv.txt but fail on the next load. but some parameter that are not set in my env nor ArmbianEnv.txt seem missing like this file size. I have only reset the default environment and set few variables, so it is easy to reset again. But I don't know how to find the extra parameters that are not set in armbianEnv.txt nor boot.scr.
Yes my environment is broken, this is the environment that I got by downloading the new u-boot image and resetting the environment to the default one. Now I am quite lost I don't know how to recover a proper environment. It seems that these erroneous root variables are in any case overridden by the boot.scr script. I see that some variables are necessary for running this script. At least ${devtype}, ${devnum}, ${distro_bootpart}, ${scriptaddr}, ${prefix}, ${filesize} some are easy like devtype=mmc devnum=0 distro_bootpart=1 prefix=boot/ I have seen elsewhere, but I don't know how to check it scriptaddr=0x6d00000 For filesize I have no idea in any case my load_script does not work. If somebody could help me to recover a proper basic environment, it would help a lot.
I try to boot for first time an espresso bin v5, I followed the advice in (Espressobin / Ultra – Armbian](https://www.armbian.com/espressobin/) and updated my uboot, and reset the environment. env default -a ## Resetting to default environment I added the image and fdt address with: setenv fdt_name boot/dtb/marvell/armada-3720-espressobin.dtb setenv image_name boot/Image setenv scriptaddr 0x6d00000 The last line is after seeing in the forum that this setting has been erased when resetting the default environment my environment is now: When I try to boot, it seems to load the initrd but never complete the boot I get: Marvell>> boot *** ERROR: `serverip' not set *** ERROR: `serverip' not set ... booting from SD 1631 bytes read in 9 ms (176.8 KiB/s) ## Executing script at 00800000 load - load binary file from a filesystem Usage: load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] - Load binary file 'filename' from partition 'part' on device type 'interface' instance 'dev' to address 'addr' in memory. 'bytes' gives the size to load in bytes. If 'bytes' is 0 or omitted, the file is read until the end. 'pos' gives the file byte position to start reading from. If 'pos' is 0 or omitted, the file is read from the start. ## Info: input data size = 2100 = 0x834 load - load binary file from a filesystem Usage: load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] - Load binary file 'filename' from partition 'part' on device type 'interface' instance 'dev' to address 'addr' in memory. 'bytes' gives the size to load in bytes. If 'bytes' is 0 or omitted, the file is read until the end. 'pos' gives the file byte position to start reading from. If 'pos' is 0 or omitted, the file is read from the start. bootm - boot application image from memory Usage: bootm [addr [arg ...]] - boot application image stored in memory passing arguments 'arg ...'; when booting a Linux kernel, 'arg' can be the address of an initrd image When booting a Linux kernel which requires a flat device-tree a third argument is required which is the address of the device-tree blob. To boot that kernel without an initrd image, use a '-' for the second argument. If you do not pass a third a bd_info struct will be passed instead Sub-commands to do part of the bootm sequence. The sub-commands must be issued in the order below (it's ok to not issue all sub-commands): start [addr [arg ...]] loados - load OS image ramdisk - relocate initrd, set env initrd_start/initrd_end fdt - relocate flat device tree cmdline - OS specific command line processing/setup bdt - OS specific bd_t processing prep - OS specific prep before relocation or go go - start OS 21764608 bytes read in 2021 ms (10.3 MiB/s) ext4load - load binary file from a Ext4 filesystem Usage: ext4load <interface> [<dev[:part]> [addr [filename [bytes [pos]]]]] - load binary file 'filename' from 'dev' on 'interface' to address 'addr' from ext4 filesystem 11618 bytes read in 12 ms (945.3 KiB/s) ## Flattened Device Tree blob at 06f00000 Booting using the fdt blob at 0x6f00000 Using Device Tree in place at 0000000006f00000, end 0000000006f05d61 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.15.48-mvebu64 (root@8b3d501f9218) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #22.05.3 SMP PREEMPT Wed Jun 22 07:22:16 UTC 2022 [ 0.000000] Machine model: Globalscale Marvell ESPRESSOBin Board [ 0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '') ..... Omitted a long boot log .... [ 2.376178] Key type fscrypt-provisioning registered [ 2.383950] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no [ 2.394740] d0012000.serial: ttyMV0 at MMIO 0xd0012000 (irq = 0, base_baud = 1562500) is a mvebu-uart [ 2.404251] printk: console [ttyMV0] enabled [ 2.404251] printk: console [ttyMV0] enabled [ 2.412987] printk: bootconsole [ar3700_uart0] disabled [ 2.412987] printk: bootconsole [ar3700_uart0] disabled [ 2.425972] xenon-sdhci d00d0000.sdhci: Got CD GPIO [ 2.464648] mmc0: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA [ 2.473851] Waiting for root device ... [ 2.512635] mmc0: new high speed SDHC card at address d6d7 [ 2.520455] mmcblk0: mmc0:d6d7 SU08G 7.40 GiB [ 2.531514] mmcblk0: p1 It seems that my boot env is incomplete. I tried with the last bullseyes and bookworm image, with the same result. I also tried the instructions in Armbian Documentation - Esspresso bin even if it seems obsolete by now, as it uses old uboot variable names, and contain a booiti command after sourcing the boot.scr script which itself contain the booti command; but I got the same result, even if the inird addr was distinct. Please what is wrong, and what I'm missing in this uboot environment.
I have no expertise in this domain, so I'm not sure it is related to your problem; but I remark that you have a typo in your env instead of scriptaddr=0x6d0000
