ManoftheSea
Contact Methods
  • Github
    github.com/ManoftheSea
  1. As far as I can tell, you've booted. OPNsense is running and unable to find the disk. I don't know anything about BSDs, or what driver you might need to find the SATA device on the espressobin. ahci0: <AHCI SATA controller> mem 0xe0000-0xe0177 irq 27 on simplebus1 This looks like it detected the controller. So yeah, I don't know why it didn't find the disk, but the problem appears to me to be the domain of freebsd, not of the bootloader firmware.
  2. br* is a bridge interface. The systemd configuration files have it set up so that all three ports are part of a single bridge. When you unmasked systemd-networkd, it probably got stuck at "waiting for network to be online", which has something like a 3 minute timeout. As you mentioned, systemd-networkd is masked by default, which is normal for every other armbian board. Switching to use Network Manager is a valid solution.
  3. Guys, are you familiar with systemd-networkd? /etc/network/interfaces is not how it's done anymore. Try checking the results of "nmcli"/"nmtui" or "networkctl" to see what is managing the interfaces, and then interact with those systems. I'm not so familiar with NetworkManager, but systemd-networkd keeps its files in /etc/systemd/network/.
  4. I was able to boot from a SATA disk that was manually setup with a GPT-formatted table and a debootstrap'ed debian arm64 kernel. The GPT partitions included: 1. BIOS from sector 34-2047, no filesystem 2. ESP from 2048-409599 (which u-boot calls bootable even if the flag isn't set), vfat filesystem 3. XBOOTLDR from 409600-819199 with bootable flag set (0x4), ext4 FS without journal 4. linux swap 5. ARM64 root (gdisk type 8305) with bit 60 set (read-only), ext4 without journal 6. linux /var (gdisk type 8310), ext4, with /srv/ and /home/ bind-mounted from /var/local/ The bootscripts/extlinux configuration live in /boot, onto which is mounted partition 3 (XBOOTLDR) next to the actual kernel/initramdisk. It is necessary to mark this partition bootable in gdisk to have the u-boot distro-boot search it for extlinux/boot.scr. While the espressobin doesn't require u-boot flashed on the boot media, this disk partition scheme would allow rockchip64 systems to boot if the BIOS partition is extended to somewhere around sector 32767 (as rockchip needs code at sector 64 and maybe 16384 and 24576).
