161 -
4333 profile views
SPI Boot [for USB or PXE without MicroSD]
mantouboji replied to ricaoalberto's topic in Orange Pi Zero 2
Zero3 root on NFS ,pxlinux cfg: LABEL linux KERNEL /zero3/vmlinuz-6.15.4-edge-sunxi64 FDTDIR /zero3/dtb-6.15.4-edge-sunxi64 DEVICETREE-OVERLAY /zero3/dtb-6.15.4-edge-sunxi64/allwinner/overlay/sun50i-h616-uart5.dtbo /zero3/dtb-6.15.4-edge-sunxi64/allwinner/overlay/sun50i-h616-spi-spidev.dtbo /zero3/overlay-user/spidev1_1.dtbo APPEND root=/dev/nfs initrd=/zero3/initrd.img-6.15.4-edge-sunxi64 nfsroot=192.168.20.20:/mnt/mass/data/linux/zero3/zero31 ip=dhcp rw rootwait DEFAULT linux
pps-gpio.dts /* * PPS-GPIO for H616/618 * * for Zero2, use PC9 * for Zero3, use PC11 * for Zero2W, use PI5, not success * * feiyao@me.com */ /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&pio>; __overlay__ { pps_pins: pps_pins { pins = "PC11"; /* Zero3 */ function = "gpio_in"; }; }; }; fragment@1 { target-path = "/"; __overlay__ { pps@0 { compatible = "pps-gpio"; pinctrl-names = "default"; /* pinctrl-0 = <&pps_pins>; */ gpios = <&pio 2 11 0>; /* PC11 @ Zero3 */ status = "okay"; }; }; }; }; compile and install: armbian-add-overlay pps-gpio.dts
This is my config, maybe it will help you a little. use UART5 to attach a GPS module, PPS connect to PC11 /boot/armbianEnv.txt overlay_prefix=sun50i-h616 overlays=uart5 user_overlays=pps-gpio param_pps_pin=PC11 /etc/default/gpsd # Devices gpsd should collect to at boot time. # They need to be read/writeable, either by user gpsd or the group dialout. DEVICES="/dev/ttyS1" # Other options you want to pass to gpsd GPSD_OPTIONS="-n -G" # Automatically hot add/remove USB GPS devices via gpsdctl USBAUTO="false" /etc/chrony/conf.d/gpstime.conf # for GPSD refclock SHM 0 refid GPS precision 1e-1 offset 0.120 delay 0.2 # for GPSD PPS , worka refclock PPS /dev/pps0 refid PPS allow all pps-gpio.dts: /* * PPS-GPIO for H616 * * for Zero2, use PC9 * for Zero3, use PC11 * for Zero2W, use PI5, not success * * feiyao@me.com */ /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&pio>; __overlay__ { pps_pins: pps_pins { pins = "PC11"; /* Zero3 */ function = "gpio_in"; }; }; }; fragment@1 { target-path = "/"; __overlay__ { pps@0 { compatible = "pps-gpio"; pinctrl-names = "default"; /* pinctrl-0 = <&pps_pins>; */ gpios = <&pio 2 11 0>; /* PC11 @ Zero3 */ status = "okay"; }; }; }; }; build and install pps-gpio.dts: sudo armbian-add-overlay pps-gpio.dts
Here: https://forum.armbian.com/topic/28425-spi-problem-with-orange-pi-3-lts/#findComment-222557
Please use Zero2, not Zero3, and use my DTS overlay, you can find it in other posts.
use my works: h616.tar.xz
follow the official instructions, change these dts to user overlay, simplicifed deployment just use `sudo make install` h616.tar.xz
spi1-cs0-pin and etc are defined in .dtsi file , since they are physical pins of the H616/H618 chip. But they are assigned to different pins of 26-PIN and 40-PIN of Zero3 and zero2w
download all files attenmented . sudo cp *.dtbo /boot/dtb/allwinner/overlay open /boot/armbianEnv.txt , add this line: overlays=spi-spidev spidev1_1 and reboot, you should find and use /dev/spidev1.1 sun50i-h616-spidev1_0.dtbo sun50i-h616-spidev1_0.dtso sun50i-h616-spidev1_1.dtbo sun50i-h616-spidev1_1.dtso
what is this? [code] [ 20.585289] ------------[ cut here ]------------ [ 20.585313] memcpy: detected field-spanning write (size 16) of single field "vif->key[pairwise][key_index]" at drivers/net/wireless/uwe5622/unisocwifi/cfg80211.c:714 (size 0) [ 20.585442] WARNING: CPU: 0 PID: 863 at drivers/net/wireless/uwe5622/unisocwifi/cfg80211.c:714 sprdwl_cfg80211_add_key+0x124/0x138 [sprdwl_ng] [ 20.585498] Modules linked in: overlay sprdwl_ng sunxi_addr cfg80211 sunrpc zram snd_soc_hdmi_codec sunxi_cedrus(C) v4l2_mem2mem videobuf2_dma_contig polyval_ce videobuf2_memops videobuf2_v4l2 polyval_generic binfmt_misc videodev snd_soc_sunxi_machine dw_hdmi_i2s_audio panfrost dw_hdmi_cec sun50i_h6_prcm_ppu snd_soc_sunxi_ahub videobuf2_common gpu_sched snd_soc_sunxi_ahub_dam mc drm_shmem_helper display_connector dump_reg cpufreq_dt sch_fq_codel sprdbt_tty uwe5622_bsp_sdio rfkill fuse motorcomm dwmac_sun8i mdio_mux sun6i_rtc_ccu [ 20.585645] CPU: 0 UID: 0 PID: 863 Comm: wpa_supplicant Tainted: G C 6.15.0-edge-sunxi64 #1 NONE [ 20.585657] Tainted: [C]=CRAP [ 20.585661] Hardware name: OrangePi Zero3 (DT) [ 20.585667] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 20.585675] pc : sprdwl_cfg80211_add_key+0x124/0x138 [sprdwl_ng] [ 20.585701] lr : sprdwl_cfg80211_add_key+0x124/0x138 [sprdwl_ng] [ 20.585725] sp : ffff80008494b740 [ 20.585730] x29: ffff80008494b740 x28: ffff0000c1d32180 x27: ffff0000c08fb080 [ 20.585745] x26: 0000000000000000 x25: ffff0000c4600a40 x24: ffff0000c4600000 [ 20.585758] x23: 0000000000000004 x22: 0000000000000004 x21: 0000000000000010 [ 20.585772] x20: 0000000000000000 x19: ffff80008494b790 x18: 00000000ffffffff [ 20.585785] x17: 0000000000000000 x16: 0000000000000000 x15: 7269772f74656e2f [ 20.585799] x14: 7372657669726420 x13: 30386766632f6966 x12: ffff8000823482d0 [ 20.585813] x11: 0000000000000001 x10: 0000000000000001 x9 : ffff8000800df178 [ 20.585826] x8 : c0000000ffffefff x7 : ffff8000822f00e8 x6 : 0000000000000001 [ 20.585840] x5 : ffff0000ff734708 x4 : 0000000000000000 x3 : 0000000000000027 [ 20.585853] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0000c1d32180 [ 20.585868] Call trace: [ 20.585874] sprdwl_cfg80211_add_key+0x124/0x138 [sprdwl_ng] (P) [ 20.585901] nl80211_new_key+0x1c4/0x320 [cfg80211] [ 20.586017] genl_family_rcv_msg_doit+0xe8/0x160 [ 20.586032] genl_rcv_msg+0x218/0x298 [ 20.586040] netlink_rcv_skb+0x68/0x140 [ 20.586053] genl_rcv+0x40/0x60 [ 20.586060] netlink_unicast+0x2f4/0x358 [ 20.586071] netlink_sendmsg+0x1b0/0x408 [ 20.586082] __sock_sendmsg+0x64/0xc0 [ 20.586093] ____sys_sendmsg+0x24c/0x2c0 [ 20.586101] ___sys_sendmsg+0xb8/0x118 [ 20.586110] __sys_sendmsg+0xa4/0x110 [ 20.586119] __arm64_sys_sendmsg+0x2c/0x40 [ 20.586128] invoke_syscall+0x50/0x120 [ 20.586142] el0_svc_common.constprop.0+0x48/0xf0 [ 20.586153] do_el0_svc+0x24/0x38 [ 20.586163] el0_svc+0x30/0xd0 [ 20.586175] el0t_64_sync_handler+0x10c/0x138 [ 20.586185] el0t_64_sync+0x198/0x1a0 [ 20.586195] ---[ end trace 0000000000000000 ]--- [/code]
sun50i-h616-spidev1_1.dtso /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target-path = "/aliases"; __overlay__ { spi1 = "/soc/spi@5011000"; }; }; fragment@1 { target = <&spi1>; __overlay__ { status = "okay"; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&spi1_pins>,<&spi1_cs1_pin>; spidev1_1: spidev@1 { compatible = "armbian,spi-dev"; status = "okay"; reg = <1>; spi-max-frequency = <1000000>; }; }; }; };
/dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target-path = "/aliases"; __overlay__ { spi1 = "/soc/spi@5011000"; }; }; fragment@1 { target = <&spi1>; __overlay__ { status = "okay"; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&spi1_pins>,<&spi1_cs1_pin>; spidev1_1: spidev@1 { compatible = "armbian,spi-dev"; status = "okay"; reg = <1>; spi-max-frequency = <1000000>; }; }; }; }; sun50i-h616-spidev1_1.dtso
pps-gpio dts file for Zero 2/3 and Zero2w
mantouboji replied to mantouboji's topic in Allwinner sunxi
/* * PPS-GPIO for H616 */ /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&pio>; __overlay__ { pps_pins: pps_pins { pins = "PC9"; // Zero2 & 3 // pins = "PI5"; // Zero2w function = "pps"; }; }; }; fragment@1 { target-path = "/"; __overlay__ { pps@0 { compatible = "pps-gpio"; pinctrl-names = "default"; pinctrl-0 = <&pps_pins>; gpios = <&pio 2 9 0>; /* PC9 */ // Zero2 & 3 //gpios = <&pio 8 5 0>; /* PI5 */ // Zero2w status = "okay"; }; }; }; };- 3 replies
- Orange Pi Zero 2
- Orange Pi Zero 3
(and 1 more)
Tagged with:
Yes, you removed this patch in 6.13: - patches.armbian/arm64-dts-sun50i-h618-orangepi-zero2w-Add-missing-nodes.patch
