Hi,
how to force set a boot resolution for this system on rockchip rk322x box?
on armbian s9xx tv box images, I append this 'video=HDMI-A-1:1920x1080M@60D' to the kernel boot line and this will force the boot resolution to be the desired one, due to its tiny font on a 4k monitor.
With the image here for rk322x, there's no uEnv.txt, but a similar armbianEnv.txt,
I tried to add 'video=HDMI-A-1:1920x1080M@60D' to be the last line in this file, but it has no effect.
my rk322x borad, it will think my 4k monitor HDMI is 5k , or 60hz, actually its only 4k@30Hz on HDMI, the result is it will blackscreen after the uboot output.
when this board connected to a Full HD monitor, it outputs fine from start to end
.. root@rk322x-box
`:]x**j-,' ---------------
.,+t***********z\<" OS: Armbian bookworm 24.11.0-trunk.192 armv7l
?******************; Host: Generic RK322x Tv Box board
'*n` .'`^,;;,^`'. ,cc. Kernel: Linux 6.6.52-current-rockchip
-<. .[l Uptime: 7 mins
// ^^ ^^ \\ Packages: 714 (dpkg)
!^ ^^ ": Shell: bash 5.2.15
'tt}` !~]rj_ ")t/. Display (U2879G6): 3840x2160 @ 30 Hz in 28″ [External]
Itttt?' ~~]rr] `{tttt, Cursor: Adwaita
\tttttt!""I_]r("""~tttttt1 Terminal: /dev/pts/0
'_tttttttttttt)ftttttttttttti. CPU: Generic DT based system (4) @ 1.39 GHz
\*ztttttttttttttttttttttttttf**[ GPU: Rockchip rk3228-mali [Integrated]
l**c)tttttttttttttttttttttttt(z**, Memory: 331.82 MiB / 977.04 MiB (34%)
.z*x.`tttttttttttttttttttttttt.`u*n Swap: 0 B / 488.52 MiB (0%)
>` (tttttttttttttttttttttt] "I Disk (/): 1.86 GiB / 6.94 GiB (27%) - ext4
,tttttttttttttttttttttt` Disk (/var/log): 7.38 MiB / 46.84 MiB (16%) - ext4
./tttttfttttttttfttttt( Local IP (end0): 192.168.19.162/24
'I)))(\()(tt))|\()({;' Locale: en_US.UTF-8
'[)))))1|()))))))?
