gtj
  1. Hello, I've been trying to install Raspotify on my NeoPlus2. While it seems to be install OK, I can't find my device available in the list of Spotify-connect capable devices. journalctl -u raspotify reports: gtj@nanopineoplus2:~$ journalctl -u raspotify -- Logs begin at Mon 2020-05-04 02:26:25 UTC, end at Mon 2020-05-04 02:43:52 UTC May 04 02:26:32 nanopineoplus2 systemd[1]: Starting Raspotify... May 04 02:26:32 nanopineoplus2 systemd[1]: Started Raspotify. May 04 02:26:32 nanopineoplus2 librespot[963]: [2020-05-04T02:26:32Z INFO libre May 04 02:26:33 nanopineoplus2 librespot[963]: thread 'main' panicked at 'called May 04 02:26:33 nanopineoplus2 librespot[963]: stack backtrace: May 04 02:26:33 nanopineoplus2 librespot[963]: 0: 0x10b13a4 - backtrace::bac May 04 02:26:33 nanopineoplus2 librespot[963]: at /cargo/ May 04 02:26:33 nanopineoplus2 librespot[963]: 1: 0x10b13a4 - backtrace::bac May 04 02:26:33 nanopineoplus2 librespot[963]: at /cargo/ May 04 02:26:33 nanopineoplus2 librespot[963]: 2: 0x10b13a4 - std::sys_commo May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 3: 0x10b13a4 - <std::sys_comm May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 4: 0x10d3ca4 - core::fmt::wri May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 5: 0x10abff0 - std::io::Write May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 6: 0x10b3954 - std::sys_commo May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 7: 0x10b3954 - std::sys_commo May 04 02:26:33 nanopineoplus2 librespot[963]: at src/lib May 04 02:26:33 nanopineoplus2 librespot[963]: 8: 0x10b3954 - std::panicking lines 1-23...skipping... -- Logs begin at Mon 2020-05-04 02:26:25 UTC, end at Mon 2020-05-04 02:43:52 UTC. -- May 04 02:26:32 nanopineoplus2 systemd[1]: Starting Raspotify... May 04 02:26:32 nanopineoplus2 systemd[1]: Started Raspotify. May 04 02:26:32 nanopineoplus2 librespot[963]: [2020-05-04T02:26:32Z INFO librespot] librespot (raspotify v0.14.0) 3672214 (2020-01-30). Built on 2020-02-16. May 04 02:26:33 nanopineoplus2 librespot[963]: thread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: Os { code: 19, kind: Other, message: "N May 04 02:26:33 nanopineoplus2 librespot[963]: stack backtrace: May 04 02:26:33 nanopineoplus2 librespot[963]: 0: 0x10b13a4 - backtrace::backtrace::libunwind::trace::hb1e9954dcc6e7c1f May 04 02:26:33 nanopineoplus2 librespot[963]: at /cargo/registry/src/github.com-1ecc6299db9ec823/backtrace-0.3.40/src/backtrace/libunw May 04 02:26:33 nanopineoplus2 librespot[963]: 1: 0x10b13a4 - backtrace::backtrace::trace_unsynchronized::h1b198a73034a9734 May 04 02:26:33 nanopineoplus2 librespot[963]: at /cargo/registry/src/github.com-1ecc6299db9ec823/backtrace-0.3.40/src/backtrace/mod.rs May 04 02:26:33 nanopineoplus2 librespot[963]: 2: 0x10b13a4 - std::sys_common::backtrace::_print_fmt::hf691518b63d0b79d May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/sys_common/backtrace.rs:84 May 04 02:26:33 nanopineoplus2 librespot[963]: 3: 0x10b13a4 - <std::sys_common::backtrace::_print::DisplayBacktrace as core::fmt::Display>::fmt::he6a16924 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/sys_common/backtrace.rs:61 May 04 02:26:33 nanopineoplus2 librespot[963]: 4: 0x10d3ca4 - core::fmt::write::hc426988e4c4119a8 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libcore/fmt/mod.rs:1025 May 04 02:26:33 nanopineoplus2 librespot[963]: 5: 0x10abff0 - std::io::Write::write_fmt::h34e90dde595ba7cd May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/io/mod.rs:1426 May 04 02:26:33 nanopineoplus2 librespot[963]: 6: 0x10b3954 - std::sys_common::backtrace::_print::h406863a8800396cd May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/sys_common/backtrace.rs:65 May 04 02:26:33 nanopineoplus2 librespot[963]: 7: 0x10b3954 - std::sys_common::backtrace::print::hec570bc9fdd6a536 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/sys_common/backtrace.rs:50 May 04 02:26:33 nanopineoplus2 librespot[963]: 8: 0x10b3954 - std::panicking::default_hook::{{closure}}::hf187be78db8e291b May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:193 May 04 02:26:33 nanopineoplus2 librespot[963]: 9: 0x10b35b4 - std::panicking::default_hook::h9634e45fc0d61ba6 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:210 May 04 02:26:33 nanopineoplus2 librespot[963]: 10: 0x10b4030 - std::panicking::rust_panic_with_hook::h35923fdea5783220 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:471 May 04 02:26:33 nanopineoplus2 librespot[963]: 11: 0x10b3c48 - rust_begin_unwind May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:375 May 04 02:26:33 nanopineoplus2 librespot[963]: 12: 0x10cfac0 - core::panicking::panic_fmt::hd74e307162bc16e5 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libcore/panicking.rs:84 May 04 02:26:33 nanopineoplus2 librespot[963]: 13: 0x10cfbac - core::result::unwrap_failed::h36f73057b442c0eb May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libcore/result.rs:1188 May 04 02:26:33 nanopineoplus2 librespot[963]: 14: 0xbeb5e0 - librespot::main::h0ed06a728ac2479f May 04 02:26:33 nanopineoplus2 librespot[963]: 15: 0xbec980 - std::rt::lang_start::{{closure}}::h3ecc962e3fb4564b May 04 02:26:33 nanopineoplus2 librespot[963]: 16: 0x10b3ac4 - std::rt::lang_start_internal::{{closure}}::hc02935a73664ebd0 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/rt.rs:52 May 04 02:26:33 nanopineoplus2 librespot[963]: 17: 0x10b3ac4 - std::panicking::try::do_call::h9ca5184b6b3cc62d May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:292 May 04 02:26:33 nanopineoplus2 librespot[963]: 18: 0x10bb220 - __rust_maybe_catch_panic May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libpanic_unwind/lib.rs:78 May 04 02:26:33 nanopineoplus2 librespot[963]: 19: 0x10b4484 - std::panicking::try::hc53e4a11b02f3299 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panicking.rs:270 May 04 02:26:33 nanopineoplus2 librespot[963]: 20: 0x10b4484 - std::panic::catch_unwind::ha972c7f8a413a94c May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/panic.rs:394 May 04 02:26:33 nanopineoplus2 librespot[963]: 21: 0x10b4484 - std::rt::lang_start_internal::hdf6cc497202d2594 May 04 02:26:33 nanopineoplus2 librespot[963]: at src/libstd/rt.rs:51 systemctl status raspotify reports: ● raspotify.service - Raspotify Loaded: loaded (/lib/systemd/system/raspotify.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-05-04 02:43:10 UTC; 7min ago Main PID: 2278 (librespot) Tasks: 3 (limit: 1022) Memory: 840.0K CGroup: /system.slice/raspotify.service └─2278 /usr/bin/librespot --name raspotify --backend alsa --bitrate 320 --disable-audio-cache --enable-volume-normalisation --linear-volume --initi May 04 02:43:10 nanopineoplus2 systemd[1]: Starting Raspotify... May 04 02:43:10 nanopineoplus2 systemd[1]: Started Raspotify. May 04 02:43:10 nanopineoplus2 librespot[2278]: [2020-05-04T02:43:10Z INFO librespot] librespot (raspotify v0.14.0) 3672214 (2020-01-30). Built on 2020-02-16 gtj@nanopineoplus2:~$ apt update Reading package lists... Done E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied) E: Unable to lock directory /var/lib/apt/lists/ W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission denied) W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission denied) gtj@nanopineoplus2:~$ sudo apt update Hit:1 http://security.debian.org buster/updates InRelease Hit:2 http://httpredir.debian.org/debian buster InRelease Get:3 http://httpredir.debian.org/debian buster-updates InRelease [49.3 kB] Get:5 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB] Hit:4 https://apt.armbian.com buster InRelease Get:6 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB] Get:7 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB] Get:8 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [27.9 kB] Get:9 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB] Get:10 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-05-04-0201.50.pdiff [860 B] Get:11 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-05-04-0201.50.pdiff [860 B] Get:12 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-05-04-0201.50.pdiff [265 B] Get:10 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-05-04-0201.50.pdiff [860 B] Get:11 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-05-04-0201.50.pdiff [860 B] Get:12 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-05-04-0201.50.pdiff [265 B] Get:13 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-05-04-0201.50.pdiff [264 B] Get:13 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-05-04-0201.50.pdiff [264 B] Fetched 210 kB in 13s (16.5 kB/s) ^C gtj@nanopineoplus2:~$ Traceback (most recent call last): File "/usr/lib/cnf-update-db", line 26, in <module> col.create(db) File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 94, in create self._fill_commands(con) File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 132, in _fill_commands self._parse_single_contents_file(con, f, fp.stdout) File "/usr/share/command-not-found/CommandNotFound/db/creator.py", line 230, in _parse_single_contents_file l.startswith('bin') or l.startswith('sbin')): KeyboardInterrupt and finally systemctl status raspotify reports: ● raspotify.service - Raspotify Loaded: loaded (/lib/systemd/system/raspotify.service; enabled; vendor preset Active: activating (auto-restart) (Result: exit-code) since Mon 2020-05-04 03 Process: 3005 ExecStartPre=/bin/mkdir -m 0755 -p /var/cache/raspotify (code=ex Process: 3006 ExecStartPre=/bin/chown raspotify:raspotify /var/cache/raspotify Process: 3008 ExecStart=/usr/bin/librespot --name ${DEVICE_NAME} $BACKEND_ARGS Main PID: 3008 (code=exited, status=1/FAILURE) May 04 03:05:38 nanopineoplus2 librespot[3008]: uses. May 04 03:05:38 nanopineoplus2 librespot[3008]: --enable-volume-normalis May 04 03:05:38 nanopineoplus2 librespot[3008]: Play all May 04 03:05:38 nanopineoplus2 librespot[3008]: --normalisation-pregain May 04 03:05:38 nanopineoplus2 librespot[3008]: Pregain May 04 03:05:38 nanopineoplus2 librespot[3008]: --linear-volume May 04 03:05:38 nanopineoplus2 librespot[3008]: increase May 04 03:05:38 nanopineoplus2 librespot[3008]: --autoplay autoplay May 04 03:05:38 nanopineoplus2 systemd[1]: raspotify.service: Main process exite May 04 03:05:38 nanopineoplus2 systemd[1]: raspotify.service: Failed with result lines 1-18/18 (END) ● raspotify.service - Raspotify Loaded: loaded (/lib/systemd/system/raspotify.service; enabled; vendor preset: enabled) Active: activating (auto-restart) (Result: exit-code) since Mon 2020-05-04 03:05:38 UTC; 32ms ago Process: 3005 ExecStartPre=/bin/mkdir -m 0755 -p /var/cache/raspotify (code=exited, status=0/SUCCESS) Process: 3006 ExecStartPre=/bin/chown raspotify:raspotify /var/cache/raspotify (code=exited, status=0/SU Process: 3008 ExecStart=/usr/bin/librespot --name ${DEVICE_NAME} $BACKEND_ARGS --bitrate ${BITRATE} $CAC Main PID: 3008 (code=exited, status=1/FAILURE) May 04 03:05:38 nanopineoplus2 librespot[3008]: uses. May 04 03:05:38 nanopineoplus2 librespot[3008]: --enable-volume-normalisation May 04 03:05:38 nanopineoplus2 librespot[3008]: Play all tracks at the same volume May 04 03:05:38 nanopineoplus2 librespot[3008]: --normalisation-pregain PREGAIN May 04 03:05:38 nanopineoplus2 librespot[3008]: Pregain (dB) applied by volume nor May 04 03:05:38 nanopineoplus2 librespot[3008]: --linear-volume May 04 03:05:38 nanopineoplus2 librespot[3008]: increase volume linear instead of May 04 03:05:38 nanopineoplus2 librespot[3008]: --autoplay autoplay similar songs when your m May 04 03:05:38 nanopineoplus2 systemd[1]: raspotify.service: Main process exited, code=exited, status=1/F May 04 03:05:38 nanopineoplus2 systemd[1]: raspotify.service: Failed with result 'exit-code'. Any help with this will be greatly appreciated!
