Kluas
  1. I just want to inform you, that tonight's system update showed this error: Hardware: Hardkernel Odroid C4 System: Armbian 25.5.2 bookworm (Debian Bookworm) --> As the issue is still present, I think I'd should going to inform you. Log: apt-get upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-bsp-cli-odroidc4-current armbian-firmware armbian-plymouth-theme base-files linux-dtb-current-meson64 linux-headers-current-meson64 linux-image-current-meson64 linux-u-boot-odroidc4-current 8 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 163 MB of archives. After this operation, 20.1 MB of additional disk space will be used. Get:1 http://apt.armbian.com bookworm/bookworm-utils arm64 base-files arm64 25.8.1-12.4+deb12u11-bookworm [53.1 kB] Err:1 http://apt.armbian.com bookworm/bookworm-utils arm64 base-files arm64 25.8.1-12.4+deb12u11-bookworm File has unexpected size (53132 != 53108). Mirror sync in progress? [IP: 198.140.141.60 80] Hashes of expected file: - SHA512:26d209e8ad9cd32687fbbda4b6cc6eaf4bb56489ad6859c5c10814d5a9a07a2a91da5dd7f02d4d4bf8d6c26d28d26dd2cf8ecc0d165445a5b80c3283f2a9c646 - SHA256:1616e5ec3540e36c9b2e566171f34d3dd720d65545c0229b9ca6f5ea417ae9e0 - SHA1:b68df5126ffa003446e4666d8c5ada4ccd70be52 [weak] - MD5Sum:69494de792a101fb2545f1446dea8ef9 [weak] - Filesize:53108 [weak] Get:2 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-bsp-cli-odroidc4-current arm64 25.8.1 [435 kB] Err:2 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-bsp-cli-odroidc4-current arm64 25.8.1 File has unexpected size (435268 != 435180). Mirror sync in progress? [IP: 198.140.141.60 80] Hashes of expected file: - SHA512:7e978f3ef834a0a01e52728dd72062f573fb7f973b3dedbdf36a6efd58972c5fab93c526a3945a9b6e0ff28a81bc4ade80029cf8ddb149f5d1a4ffaf8a6c2ab1 - SHA256:dc3f93c3de4bd694314451f1e7b257ff582d8ec728f206c557146666aefdc258 - SHA1:7354b3476c9b0972d60dab62fc5352246791d2e1 [weak] - MD5Sum:a8e1f40bf17e6e2b6d7765ef03fb77e2 [weak] - Filesize:435180 [weak] Get:3 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-firmware all 25.8.1 [95.9 MB] Ign:3 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-firmware all 25.8.1 Err:3 http://apt.armbian.com bookworm/main arm64 armbian-firmware all 25.8.1 File has unexpected size (95947948 != 95947672). Mirror sync in progress? [IP: 198.140.141.60 80] Get:4 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-plymouth-theme all 25.8.1 [112 kB] Ign:4 http://xogium.performanceservers.nl/apt bookworm/main arm64 armbian-plymouth-theme all 25.8.1 Err:4 http://apt.armbian.com bookworm/main arm64 armbian-plymouth-theme all 25.8.1 File has unexpected size (112064 != 112032). Mirror sync in progress? [IP: 198.140.141.60 80]
  2. Thanks for clarification.
  3. To my understanding it was introduced by kernel commit 91562895f803, which was accepted by kernel team https://lore.kernel.org/linux-ext4/87bkbbijwt.fsf@doe.com/T/ I didn't find any changelogs for the kernel on my Armbian host. I looked into these changelogs, but didn't find any data: zless /usr/share/doc/linux-dtb-current-meson64/changelog.gz zless /usr/share/doc/linux-image-current-meson64/changelog.gz --> I'm unsure, if I'm affected. FUD., On the other side, on the Debian Users ML are reports, that Debian Bookworm is affected: https://lists.debian.org/debian-user/2023/12/msg00500.html More FUD on my site. As I don't have a changelog, and people are saying that my distribution (bookworm) is affected, I can only assume that Armbian is very likely affected too. But I'm glad to here, that I'm not. Thank you.
  4. Please move this message to correct folder, if I used the wrong one. There is a grave bug in the ext4 FS, which was introduced in kernel around 6.1.55 and is fixed in kernel 6.1.66. The bug is causing data coruption and data loss, like new packages aren't installed properly. A fix was introduced today into kernel, in version 6.1.66 Armbian Bookworm 23.11.1 (Debian) comes with 6.1.63 and, according to my knowledge, is affected. When will new kernel packages from armbian be available? References: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=1057843 https://fulda.social/@Ganneff/111551628003050712
