PSL
  1. I tried to replicate this issue on i686 box running Debian Bookworm and it works there, no problem. 1) Create file for disk, 50GB # dd if=/dev/zero of=xfstest.bin bs=1M count=50000 2) Format disk with XFS # mkfs.xfs xfstest.bin 3) show XFS details # xfs_info xfstest.bin meta-data=/dev/loop0 isize=512 agcount=4, agsize=3276800 blks = sectsz=512 attr=2, projid32bit=1 = crc=1 finobt=1, sparse=1, rmapbt=0 = reflink=1 bigtime=1 inobtcount=1 nrext64=0 data = bsize=4096 blocks=13107200, imaxpct=25 = sunit=0 swidth=0 blks naming =version 2 bsize=4096 ascii-ci=0, ftype=1 log =internal log bsize=4096 blocks=16384, version=2 = sectsz=512 sunit=0 blks, lazy-count=1 realtime =none extsz=4096 blocks=0, rtextents=0 4) mount FS, no issue here! # mount -o loop xfstest.bin /srv # # mount | grep xfs /root/xfstest.bin on /srv type xfs (rw,relatime,attr2,inode64,logbufs=8,logbsize=32k,noquota) 5) check dmesg # dmesg | grep XFS [2992759.600513] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled [2992759.618175] XFS (loop0): Mounting V5 Filesystem [2992759.649994] XFS (loop0): Ending clean mount 6) system info, kernel is 6.1.0 # uname -a Linux worm 6.1.0-12-686-pae #1 SMP PREEMPT_DYNAMIC Debian 6.1.52-1 (2023-09-07) i686 GNU/Linux # # dpkg -l | grep xfsprogs ii xfsprogs 6.1.0-1 i386 Utilities for managing the XFS filesystem So, I assume that issue is really the kernel 5.x that is delivered with Armbian for Odroid XU4 (HC1/HC2)...
  2. Maybe kernel is old, it is 5.4 in this build. Other builds of Armbian have kernel 6.1.53 (like OrangePi ZERO or NanoPI NEO)...
  3. I installed "Armbian 23.8.3 bookworm" to Odroid HC1. Installation was OK, it boots. Armbian is installed on microSDHC card. I wanted to format SATA drive with XFS but I cannot mount it. 1) I installed xfsprogs (apt install xfsprogs) $ dpkg -la | grep xfs ii xfsprogs 6.1.0-1 armhf Utilities for managing the XFS filesystem 2) I created GPT partition table on SATA drive and I created one partition, /dev/sdb1 # fdisk -l /dev/sdb Disk /dev/sdb: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors Disk model: Generic Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: EF0AF689-AAD7-C443-B5AE-03EFFC99E02D Device Start End Sectors Size Type /dev/sdb1 2048 3907028991 3907026944 1.8T Linux filesystem 3) I formated partition with xfs: # mkfs.xfs /dev/sdb1 4) I checked partition with xfs_repair, no issues # xfs_repair /dev/sdb1 5) Info about filesystem: # xfs_info /dev/sdb1 meta-data=/dev/sdb1 isize=512 agcount=4, agsize=122094592 blks = sectsz=4096 attr=2, projid32bit=1 = crc=1 finobt=1, sparse=1, rmapbt=0 = reflink=1 bigtime=1 inobtcount=1 nrext64=0 data = bsize=4096 blocks=488378368, imaxpct=5 = sunit=0 swidth=0 blks naming =version 2 bsize=4096 ascii-ci=0, ftype=1 log =internal log bsize=4096 blocks=238466, version=2 = sectsz=4096 sunit=1 blks, lazy-count=1 realtime =none extsz=4096 blocks=0, rtextents=0 6) The issue, I cannot mount the partition: # mount /dev/sdb1 /srv/ mount: /srv: wrong fs type, bad option, bad superblock on /dev/sdb1, missing codepage or helper program, or other error. dmesg(1) may have more information after failed mount system call. # dmesg |grep XFS [ 7578.496569] SGI XFS with ACLs, security attributes, realtime, no debug enabled ... [ 7578.525167] XFS (sdb1): Superblock has unknown read-only compatible features (0x8) enabled. [ 7578.525175] XFS (sdb1): Attempted to mount read-only compatible filesystem read-write. [ 7578.525180] XFS (sdb1): Filesystem can only be safely mounted read only. [ 7578.525201] XFS (sdb1): SB validate failed with error -22. # uname -a Linux hc1 5.4.253-current-odroidxu4 #2 SMP PREEMPT Mon Aug 14 01:33:04 UTC 2023 armv7l GNU/Linux Any idea what is broken? Is it kernel??
