I can confirm that the T95 Max+ (Plus) is booting under the mentioned limitations (no WiFi, no Bluetooth, 100 Mbps) using the Server image Armbian Linux 6.6 Ubuntu 24.04 (Noble). I haven't tested installing to emmc, though.
TV Box Name: T95 Max+ (Plus)
CPU: S905x3
Armbian build file name: Armbian_community_25.2.0-trunk.160_Aml-s9xx-box_noble_current_6.6.65.img
DTB file used: /dtb/amlogic/meson-sm1-x96-air.dtb or /dtb/amlogic/meson-sm1-sei610.dtb
Kernel Version: 6.6.65
Distribution Installed: Noble (Ubuntu)
Working Ethernet: Yes
Max Ethernet Speed that works: 100 Mbps
Does wifi work: No
Does bluetooth work: No
Does HDMI audio work: No
Additional Comments (provide any additional information you feel is important):
I had to rename u-boot-s905x3 to u-boot.ext to boot successfully.
apt update && apt upgrade worked fine after installation at the time of 12/18/2024. However, it may still be advisable to freeze the packages mentioned in the original post.
/dtb/amlogic/meson-sm1-x96-air-gbit.dtb did not work (no Ethernet at all).
