indianajones
1 Follower
  1. @Igor Thanks for that, I guess I can move on to the newer tools. So does that mean that the GOVERNOR and CPUMIN params are useless and can be discarded? And BTW your Armbian tools are utterly fantastic.
  2. This issue isn't for orangepione, but for nanopineo - which I can't find in the dropdowns anymore. Perhaps it is no longer supported. I'm able to build a working image using this command: ./compile.sh BOARD=nanopineo BRANCH=current RELEASE=noble BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=xz However, if I add the CPU governance variables, such as this: ./compile.sh BOARD=nanopineo BRANCH=current RELEASE=noble BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=xz CPUMIN=81600 CPUMAX=96000 ...the build fails with the following error text: ./compile.sh mike [🚸] This script requires root privileges; Docker is unavailable [ trying to use sudo ] [🌿] Applying cmdline param [ 'PREFER_DOCKER': '(unset)' --> 'no' early ] [🌱] Skip cmdline param [ 'ARMBIAN_RELAUNCHED': already set to 'yes' early ] [🌿] Applying cmdline param [ 'SET_OWNER_TO_UID': '(unset)' --> '1000' early ] [🌱] Skip cmdline param [ 'PREFER_DOCKER': already set to 'no' after config 'config-mike.conf' ] [🌱] Skip cmdline param [ 'ARMBIAN_RELAUNCHED': already set to 'yes' after config 'config-mike.conf' ] [🌱] Skip cmdline param [ 'SET_OWNER_TO_UID': already set to '1000' after config 'config-mike.conf' ] [🌱] Starting single build process [ nanopineo ] [🌱] Checking [ basic host setup ] [🌱] Build host OS release [ noble ] [🌱] Build host architecture [ arm64 ] [🌱] Sourcing board configuration [ /home/mike/build/config/boards/nanopineo.csc ] [βœ…] change-tracking: after sourcing board file config/boards/nanopineo.csc [ BOARDFAMILY='sun8i' ] [βœ…] change-tracking: after sourcing board file config/boards/nanopineo.csc [ BOOTCONFIG='nanopi_neo_defconfig' ] [βœ…] change-tracking: after defaulting LINUXFAMILY to BOARDFAMILY [ LINUXFAMILY='sun8i' ] [🌱] Starting main configuration [🌱] Using REVISION from [ main VERSION file: '25.11.0-trunk' ] [🌿] Enabling extension [ armbian-config ] [🌱] Sourcing family configuration [ /home/mike/build/config/sources/families/sun8i.conf ] [🌿] Enabling extension [ sunxi-tools ] [πŸ’₯] Error 1 occurred in main shell [ at /home/mike/build/lib/functions/configuration/main-config.sh:552 source_family_config_and_arch() --> lib/functions/configuration/main-config.sh:552 do_main_configuration() --> lib/functions/configuration/main-config.sh:291 do_with_logging() --> lib/functions/logging/section-logging.sh:81 do_with_conditional_logging() --> lib/functions/logging/section-logging.sh:111 prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:29 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:208 main() --> compile.sh:50 ] I looked at the source_family_config_and_arch() function source, and the file that gets passed into it (/home/mike/build/config/sources/families/sun8i.conf) exists on my box, but something is causing the failure at line 552 anyway. What's strange is that the exact same LINUXFAMILY / BOARDFAMILY is configured in my working command (with all the params passed on the cmdline), like this: 🌱] Sourcing board configuration [ /home/mike/build/config/boards/nanopineo.csc ] [βœ…] change-tracking: after sourcing board file config/boards/nanopineo.csc [ BOARDFAMILY='sun8i' ] [βœ…] change-tracking: after sourcing board file config/boards/nanopineo.csc [ BOOTCONFIG='nanopi_neo_defconfig' ] [βœ…] change-tracking: after defaulting LINUXFAMILY to BOARDFAMILY [ LINUXFAMILY='sun8i' ] [🌱] Starting main configuration [🌱] Using REVISION from [ main VERSION file: '25.11.0-trunk' ] [🌿] Enabling extension [ armbian-config ] [🌱] Sourcing family configuration [ /home/mike/build/config/sources/families/sun8i.conf ] [🌿] Enabling extension [ sunxi-tools ] [βœ…] change-tracking: after sourcing family config [ KERNEL_MAJOR_MINOR='6.12' ] [βœ…] change-tracking: after sourcing family config [ LINUXFAMILY='sunxi' # (was: 'sun8i') ] [βœ…] change-tracking: after sourcing family config [ KERNELPATCHDIR='archive/sunxi-6.12' ] [βœ…] change-tracking: after sourcing family config [ BOOTBRANCH='tag:v2024.01' ] [βœ…] change-tracking: after sourcing family config [ BOOTPATCHDIR='u-boot-sunxi' ] [βœ…] change-tracking: after sourcing family config [ NETWORKING_STACK='network-manager' ] The build/config/sources/families/sun8i.conf file, referenced in the log output, contains a proper CPUMIN and CPUMAX, so I'm not sure why specifying them on the command line blows up the build. # SPDX-License-Identifier: GPL-2.0 # # Copyright (c) 2013-2023 Igor Pecovnik, igor@armbian.com # # This file is a part of the Armbian Build Framework # https://github.com/armbian/build/ # # shellcheck source=config/sources/families/include/sunxi_common.inc source "${BASH_SOURCE%/*}/include/sunxi_common.inc" if [[ -z ${OVERLAY_PREFIX} ]]; then OVERLAY_PREFIX='sun8i-h3' fi [[ -z $CPUMIN ]] && CPUMIN=480000 [[ -z $CPUMAX ]] && CPUMAX=1400000 Any thoughts on what I'm doing wrong?
Γ—
Γ—
