Keerati
  1. Hi! just want to share the experience. I'm using Armbian in an environment that cannot access the internet. So, NTP becomes a big issue, and I have to setup my local NTP server using Chrony. Things should be simple, but it just didn't work out. I stuck with this problem for a few weeks until I realized I'm trying to setup Chrony NTP server on a virtual machine. Then, I found this one on stackoverflow. https://serverfault.com/questions/1062023/the-least-bad-settings-for-chrony-as-the-ntp-server-on-a-virtual-machine It suggests how to setup NTP server on virtual machine, but I didn't follow through as I solved my problem by setting up Chrony NTP server on a physical server instead. So, just want to share the experience in case anyone stuck with similar problems as mine.
