fscii
  1. Short answer is follow this guide to the letter and it should work. https://wiki.omv-extras.org/doku.php?id=omv7:armbian_bookworm_install
  2. I have finally got mine to work. run these two commands and post the results ip a networkctl list
  3. Ok here it is -- it also generated an error running the script. root@omv:~# armbianmonitor -u Collecting info and sending to paste.armbian.com, wait... /usr/bin/armbianmonitor: line 976: iostat: command not found https://paste.armbian.com/huqolomoku
  4. Running ODroid HC4 on Armbian bookworm with Openmediavault 7 with docker compose plugin. I've done 2 clean installs to ensure the problem is reproducable and not something I meddled with. I spent time on Docker's forums running sample containers I was asked to try, they viewed my settings logs for docker and were at a loss. The containers go up fine and are running. They just cannot be accessed even from the host machine e.g. curl http://localhost:8080 fails when running a sample container docker hub forums supplied me with as a 'surefire' test. --- services: test_default_bridge: image: nginx:latest network_mode: bridge ports: - 8080:80 Is anyone else having this issue and how do I get it working?
  5. Thanks for the info and assistance. I ended up finding how to DIY install and got it up and running that way. Here's the link I used: OMV Manual Installation for Debian
  6. I was running Armbian Bullseye for a while with OMV 6. I happened to see OMV has gone to v7 and Armbian to bookworm. I went here to get the SBC/IOT bare version of bookworm: https://www.armbian.com/odroid-hc4/ Problem 1: is it said: "You are using an automated version meant only for developers..." Problem 2: it did not come with Armbian-config which I had to install manually Problem 3: Armbian-config 'softy' refused to install OMV saying it can only be installed on Buster (OMV5) or Bullseye (OMV6) Finally: https://wiki.omv-extras.org/doku.php?id=omv7:armbian_bookworm_install states specifically not to use any developer versions of the OS. Is there a stable version of the OS where it comes with Armbian-config and softy will install OMV-7? (If so, url's please) How do I proceed? For now going back to Bullseye OMV6 Much thanks in advance.
