6 -
Cannot boot from EMMC storage on expresso bin
Henrique Fernandes replied to Henrique Fernandes's topic in Marvell mvebu
I'm actually more confused now, I thought U-Boot had to be flashed, didn't know you could just install it via .deb package. -
I'd help if I could but I don't understand anything about low level coding and building U-boot. Glad to see your stepping up to become a maintainer of the board, I'm sure you will do great. -
Thanks alot for the help so far. You were right after all, by mistake I wrote `rootdev=0c7e2e6c-ee84-4ec3-9971-27e6020600cf` on armbianEnv.txt instead of `rootdev=UUID=0c7e2e6c-ee84-4ec3-9971-27e6020600cf`, after changing like you suggested armbian does boot on the EMMC module, as long the microSD is inserted with said line on armbianEnv.txt. I'm still at a loss on how to make uboot recognize the emmc storage and boot armbian without the microSD card. -
NO JOY 🙁 I also reran the amrbian-config utility to reintall armbian on the emmc, hence the UUID change, but changing amrbianEnv.txt rootdev booted in initramsfs: Begin: Will now check root file system ... fsck from util-linux 2.31.1 Checking all file systems. done. mount: mounting 0c7e2e6c-ee84-4ec3-9971-27e6020600cf on /root failed: No such file or directory done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... mount: mounting /dev on /root/dev failed: No such file or directory mount: mounting /dev on /root/dev failed: No such file or directory done. mount: mounting /run on /root/run failed: No such file or directory run-init: current directory on the same filesystem as the root: error 0 Target filesystem doesn't have requested /sbin/init. run-init: current directory on the same filesystem as the root: error 0 run-init: current directory on the same filesystem as the root: error 0 run-init: current directory on the same filesystem as the root: error 0 run-init: current directory on the same filesystem as the root: error 0 run-init: current directory on the same filesystem as the root: error 0 No init found. Try passing init= bootarg. BusyBox v1.27.2 (Ubuntu 1:1.27.2-2ubuntu3.4) built-in shell (ash) Enter 'help' for a list of built-in commands. (initramfs) I chrooted, reverted to the previous UUID and rebooted, could this error mean something else is broken? Pardon my ignorance, but I don't know how to tell uboot to use it 😐 Also I don't know how to edit the dtb file outside of armbian-config. -
Hello, [short version] My expresso bin V5 only boots from the micro sd card and I would like it to boot from the EMMC module. [long version] My old old expresso bin V5 did not came with a pre installed EMMC module, I had a 16gb kingston EMMC module from aliexpress soldered onto it, the EMMC module is correctly detected by armbian bionic as seen from the output of blkid as /dev/mmcblk0p1: /dev/mmcblk0p1: UUID="dc265376-877d-40a1-9417-7379fb332efe" TYPE="ext4" PARTUUID="36c210f9-01" /dev/mmcblk1p1: LABEL="root" UUID="621decff-6765-4dbd-ae8c-c7e2d5c0193d" TYPE="ext4" PARTUUID="04b226a1-01" /dev/mmcblk1p3: LABEL="home" UUID="df5bfbe2-de80-49b4-ac8f-2378fd736e4f" TYPE="ext4" PARTUUID="04b226a1-03" /dev/zram0: LABEL="log2ram" UUID="1d15f838-3c4d-4acf-a58c-fde890ecdea9" TYPE="ext4" /dev/mmcblk0: PTUUID="36c210f9" PTTYPE="dos" /dev/mmcblk1: PTUUID="04b226a1" PTTYPE="dos" /dev/zram1: UUID="c759b67d-75a8-4452-95a8-fe45f11d1e4c" TYPE="swap" I can mount, read and write on /dev/mmcblk0p1, initially I ran armbian-config to install armbian on the EMMC module and it worked with a weird shortcoming, it would only boot from the EMMC module if a micro SD card was inserted on the board, I could tell right away from the "Usage of /:" field on the amrbian prompt from which storage device I had booted but I also checked the UUID on fstab and boot.cmd to make sure. uboot threw an error message saying Card did respond to voltage select! whenever I tried to boot without a micro SD card on the expresso bin From here on out what I did made matters much worse, I figured uboot was the problem and decided to update it to a newer version without backing up the on I had on the board from February 2019(stupid of me), so I downloaded and installed the lastest version I could find on https://xogium.performanceservers.nl/archive/espressobin/u-boot/ Ever since I cannot boot from the EMMC module with or without a micro SD card on the expressobin and uboot does not detect it at all, since the following command only prints one device when it used to print 2: Marvell>> mmc list sdhci@d0000: 0 I'm still able to mount and write stuff to the EMMC storage while on bionic as before, but on uboot it's like it doesen't exist. The uboot environment is like this: Marvell>> env print arch=arm baudrate=115200 board=mvebu_armada-37xx board_name=mvebu_armada-37xx boot_a_script=ext4load ${boot_interface} ${devnum}:1 ${scriptaddr} ${prefix}boot.scr;source ${scriptaddr}; boot_interface=mmc boot_prefixes=/ /boot/ boot_targets=usb sata mmc1 mmc0 bootargs=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=UUID=dc265376-877d-40a1-9417-7379fb332efe rootfstype=ext4 rootwait loglevel=1 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u mtdparts=spi0.0:1536k(uboot),64k(uboot-environment),-(reserved) bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done bootcmd_mmc0=setenv devnum 0; setenv boot_interface mmc; run scan_dev_for_boot; bootcmd_mmc1=setenv devnum 1; setenv boot_interface mmc; run scan_dev_for_boot; bootcmd_sata=setenv devnum 0; scsi scan; scsi dev 0; setenv boot_interface scsi; run scan_dev_for_boot; bootcmd_usb=setenv devnum 0; usb start;setenv boot_interface usb; run scan_dev_for_boot; bootdelay=2 console=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 cpu=armv8 devnum=0 emmc_fix=on eth1addr=06:8E:A0:24:0F:88 eth2addr=00:50:43:84:25:2f eth3addr=00:50:43:0d:19:18 ethact=neta@30000 ethaddr=F0:AD:4E:03:64:7F ethprime=eth0 extra_params=pci=pcie_bus_safe fdt_addr=0x6000000 fdt_addr_r=0x6f00000 fdt_high=0xffffffffffffffff fdt_name=fdt.dtb fdt_name_a=dtb/marvell/armada-3720-community.dtb fdt_name_b=dtb/marvell/armada-3720-espressobin.dtb fdtcontroladdr=3f62d490 fileaddr=6d00000 filesize=ea gatewayip=10.4.50.254 get_images=tftpboot $kernel_addr_r $image_name; tftpboot $fdt_addr_r $fdt_name; run get_ramfs get_ramfs=if test "${ramfs_name}" != "-"; then setenv ramdisk_addr_r 0x8000000; tftpboot $ramdisk_addr_r $ramfs_name; else setenv ramdisk_addr_r -;fi hostname=marvell image_name=Image initrd_addr=0x1100000 initrd_image=uInitrd initrd_size=0x2000000 ipaddr=0.0.0.0 kernel_addr=0x7000000 kernel_addr_r=0x7000000 loadaddr=0x8000000 netdev=eth0 netmask=255.255.255.0 ramdisk_addr_r=0x8000000 ramfs_name=- root=root=/dev/nfs rw rootdev=UUID=dc265376-877d-40a1-9417-7379fb332efe rootfstype=ext4 rootpath=/srv/nfs/ scan_dev_for_boot=for prefix in ${boot_prefixes}; do echo ${prefix};run boot_a_script; done scriptaddr=0x6d00000 serverip=0.0.0.0 set_bootargs=setenv bootargs $console $root ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:none nfsroot=$serverip:$rootpath,tcp,v3 $extra_params $cpuidle soc=mvebu stderr=serial@12000 stdin=serial@12000 stdout=serial@12000 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u vendor=Marvell verbosity=1 Environment size: 2655/65532 bytes While booting, uboot throws these errors: / ** Bad device usb 0 ** ## Executing script at 06d00000 Wrong image format for "source" command /boot/ ** Bad device usb 0 ** ## Executing script at 06d00000 Wrong image format for "source" command scanning bus for devices... Device 0: unknown device / ** Bad device scsi 0 ** ## Executing script at 06d00000 Wrong image format for "source" command /boot/ ** Bad device scsi 0 ** ## Executing script at 06d00000 Wrong image format for "source" command / ** Bad device mmc 1 ** ## Executing script at 06d00000 Wrong image format for "source" command /boot/ ** Bad device mmc 1 ** ## Executing script at 06d00000 Wrong image format for "source" command / ** File not found /boot.scr ** ## Executing script at 06d00000 Wrong image format for "source" command /boot/ Any help in getting amrbian booting from the recently soldered EMMC module would be greatly appreciated.
