eloirotava
Other groups
Support
1 Follower
  1. Hey guys and @jock. Thanks for the references. not very fast, but stable and working on a s905w. (guess to be a tx3 mini, but who knows...) kernel 6.18.10 and ssv6051p. Linux aml-s9xx-box 6.18.10-current-meson64 #3 SMP PREEMPT Wed Feb 11 12:42:01 UTC 2026 aarch64 GNU/Linux with speedtest-cli Download: 3.43 Mbit/s Upload: 1.55 Mbit/s yeah, slow. but stable... i guess dmesg [ 11.938463] SSV WLAN driver ssv6200: chip id: RSV6200A0-201311, tag: 2014012420010960 [ 12.006600] SSV WLAN driver ssv6200: attempt to load firmware ssv6051-sw.bin [ 12.021645] SSV WLAN driver ssv6200: firmware upload complete (wrote 80 blocks, verified 80 blocks) [ 12.138546] SSV WLAN driver ssv6200: Firmware version 16380 [ 12.141013] SSV WLAN driver ssv6200: Calibration successful https://github.com/eloirotava/6051 the repo has also the rtl8188fu driver to the same soc/kernel. it is better than the ssv for sure... The trick was tuning the ssv6051-wifi.cfg to disableHT/AMPDU that usually kill the SDIO bus on these SOCs.
  2. after some research i have (finally) found the original archives form balbes. they can also been burn to the internal eemc. with some work you can run bookworm with kernel 3.10.99 (dont ask why) from the internal storage... https://archive.org/details/amlogic-s805-linux tks for 0jw4tts witch uploaded those files to archive.og !!!
  3. It looks like the issue is likely related to display resolution settings if you can see the initial boot text but get a black screen with "no signal" once the GUI loads. Try the following steps: Switch to a TTY session If the system is running but the display is not working, press Ctrl + Alt + F1 (or F2, F3, etc.) to access a terminal. Check the current display settings If you can log in via SSH or TTY, try running: "xrandr" This will list the available resolutions. If the default resolution is not supported by your LCD panel, you may need to adjust it manually.
  4. On a headless machine, I use Xvfb (a virtual display server) and x11vnc to enable remote access. Here's what works for me: Xvfb :1 -screen 0 1280x720x16 & DISPLAY=:1 startx & x11vnc -display :1 -rfbport 5900 -forever & Make sure you have Xvfb and x11vnc installed! Xvfb :1 -screen 0 1280x720x16 → Starts a virtual display at :1 with a resolution of 1280x720 and 16-bit color depth. DISPLAY=:1 startx → Starts the X session using the virtual display. x11vnc -display :1 -rfbport 5900 -forever → Starts the VNC server on display :1, keeping the session active after disconnects.
  5. Hi! You should use netmask 255.255.255.0 instead of subnetmask. If NetworkManager is managing your interfaces, it might override manual settings. Try disabling it or configuring the static IP within nmcli. Let me know if you need more help! Thanks, Eloi.
