s-petersen
2 Followers
2115 profile views
  1. Did you download stretch already, before I remove it to put up Bionic?
  2. If you guys want Bionic, I can remove stretch, and link it. You should try to download stretch again, and try a different SD card before anything else.
  3. Has it booted at all?
  4. When mine died, it was in text mode, playing Mp3's
  5. yes, I ran mine from SD the whole time, but my box died because I never upgraded the cpu heatsink, they run too hot unless you upgrade. I even installed Python, and used a usb to 12s so I could control inputs and outputs for controlling things
  6. From what I remember it wasn't possible at the time it was abandoned
  7. I can upload Bionic also, but I have to remove Stretch first due to space on dropbox. Bionic is newer, but Bionic had more issues with it on my box. Install a bigger heatsink, or fan because my box failed due to overheating.
  8. This was the best working version, I also have bionic https://www.dropbox.com/scl/fi/cubr0yu3t9garv3rxzarg/Armbian_5.67_Aml-s805_Debian_stretch_default_3.10.108_desktop_20181207.img-1.xz?rlkey=remqj5qcnwyjl3t943qj3uh4l&dl=0
  9. I did find the files in a backup, now have to find a way to post them...
  10. I have been looking, but all of the links are dead, I might have a copy, but I possibly deleted it a month or 2 ago. I will look some more tomorrow, I might have it in a backup, I will let you know
  11. I have stopped working with the box, since mine failed, and the Raspberry Pi zero is cheap again. The last old image was working well before my box failed, the S805 was no longer supported when I started using it. I had bought it for $1 at a hamfest as a project to figure them out.
  12. I would use it as a conversion of a jukebox to MP3, using it in place of the Mbox (Mbox hardware failed) I tried during the pandemic
  13. TV Box Name MXQ MBX Model M201 CPU (example: amlogic s805 Meson 8B 4 cores 1.5 Ghz Armbian build file name:Armbian_5.67_Aml-s805_Ubuntu_bionic_default_3.10.108_desktop_20181207 DTB file used: Kernel Version:3.10.108 #14 SMP preenpt Distribution Installed (focal, buster, etc):Bionic Working Ethernet not tested Max Ethernet Speed that works (100/1000): Does wifi work Yes sort of, makes breaks connection continually, it will download updates Does bluetooth work (Yes/No):NA I don't know if the box has it Does HDMI audio work (Yes/No):Not tested Additional Comments (provide any additional information you feel is important): Headphone audio works although it is not perfect. Keyboard and mouse work fine, I have no remote to test Sound:AML8AUDIO Video playback is slow, I'm not sure if accelerated video is working Video:Mali-450 MP Booted fine, and updated fine 815 available memory
