luisfmrosa
  1. Igor, really sorry, I didn't mean to be rude. This error with ZFS really put me out of my comfort zone! But thanks to this forum, all is solved now.
  2. Hello, ==> UPDATE: I finally managed to fix the issue by moving away from current kernel and installing the edge one: on armbian-config, install "edge" kernel (5.17.5-meson64) install manually the kernel header (armbian-config only install "current" kernel header, i.e., 5.10.*): sudo apt install linux-headers-edge-meson64 sudo apt remove zfs-dkms sudo apt install zfs-dkms sudo apt install zfsutils-linux Then I managed to recover my zfs pool with: sudo zpool import -f mypool sudo zpool upgrade mypool Now it's working again! 🥰 It's me again. I have been busy since my last attempt to fix my ZFS issues, but now I found some time to start from zero: grabbed the latest version from https://redirect.armbian.com/odroidhc4/Jammy_current, installed on my SD card with Balena Etcher, and recreated my system from zero. I installed the kernel headers with armbian-config, as it was not activated by default, and then, I followed the same steps as described above in @Igor's post: Then started apt upgrade: While doing apt upgrade, I had 2 issues appeared, saying /etc/issue and /etc/issue.net were different from maintainers. I assume it's not a big deal, installed from the maintainer and continued: Then it continued the upgrade without noticeable issue: Then I tried to install zfs... and it doesn't work: sudo apt install zfs-dkms It starts by showing a message about licence incompatibility. I select 'OK' to continue... and then, it crashes! It says "Unable to build an empty module": What did I do wrong?! I would be grateful if someone could help me to solve it. All my NAS data is bricked. 🥵 I don't understand why it's so difficult to have ZFS running on my ODROID HC4 (but it worked in the past with an older version) ... this raises another question: shall I move away from ZFS for peace of mind? Thank you, guys! And sorry to bother you again. Luis
