lucab
  1. Hi All. I have just installed Armbian v22.08 (2022-08-30). It says it has zfs support, so I have tried running sudo apt-get install zfsutils-linux zfs-dkms. It returns an error. So I tried to follow @Greek64 suggestion, but the path /usr/src/ is empty. I used armbian-config to install software -> header_install. The progress bar appears but it exits immediately, like nothing happened. Any suggestions? Thanks, Luca
  2. Hi All, On an Odroid N2+ board, I have tried to install ZFS following different suggestions I found on the web. None of them worked so far. I tried: https://forum.armbian.com/topic/19952-cant-install-kernel-headers-via-armbian-config/ https://forum.armbian.com/topic/18790-odroidhc4-with-5139-meson64-missing-zfs-modules/ https://forum.armbian.com/topic/17337-zfs-just-works-now-on-armbian-2-step-instructions-if-you-are-thick-like-me/ I installed both Armbian 22.05 Bullseye 5.10.110-meson64 first, and then Jammy 5.17. Could someone please help me? Thanks 🙂
