Thank you very much all.
I could install armbian; the problem was related to the HDMI issue that doesn't work on my device, and the led keep red.
The interesting part is that I bought the device as a 4gb ram (and android shows 4gb) while it only has 1.5GB when I checked by armbian!
I also took another image with a higher quality might be useful:
It is almost impossible to remove the heatsink, but as I checked carefully I could see the bga pins only.
Thanks. You solved my problem. I checked all the SD-card/USBs and Ethernet pins for the UART part, but I couldn't get any result.
