oneofthemany
10 -
It's not a criticism of your development, far from it, I'm very pleased with Armbian and it's device support. I potentially need to investigate further and if I find anything I'll be sure to let you know
It's not particularly stable, as it won't reboot properly and I have to manually pull the plug to get it to come back up, but for what I'm using it for it should be ok
its cool I have just flashed it with debian and its up and running and its all good: super@rock-3a:~$ iw dev phy#0 Interface wlp1s0 ifindex 3 wdev 0x1 addr 00:0a:52:08:ad:fa type managed txpower 20.00 dBm multicast TXQ: qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets 0 0 0 0 0 0 0 0 0 super@rock-3a:~$ lspci 0000:00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3568 Remote Signal Processor (rev 01) 0000:01:00.0 Unclassified device [0002]: MEDIATEK Corp. MT7915E 802.11ax PCI Express Wireless Network Adapter 0002:00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3568 Remote Signal Processor (rev 01) super@rock-3a:~$ dmesg | grep 7915 [ 2.891786] pci 0000:01:00.0: [14c3:7915] type 00 class 0x000280 [ 13.721849] mt7915e 0000:01:00.0: enabling device (0000 -> 0002) [ 13.918517] mt7915e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20220929104113a [ 13.945336] mt7915e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20220929104145 [ 13.985161] mt7915e 0000:01:00.0: WA Firmware Version: DEV_000000, Build Time: 20220929104205 [ 14.343207] mt7915e 0000:01:00.0 wlp1s0: renamed from wlan0
@Igor I have used the compile tool to bake a new kernel for the rock3a and the device is just flashing blue and wont boot. I have tried server and desktop and its just the same: -------------------------------------------------------------------------------- Title: Armbian 23.08.0-trunk Rock-3a current Kernel: Linux 6.1.44 Build date: 09.08.2023 Builder rev: 35feddc The only thing I edited in the kernel config was was the MT7917E to M Any ideas? - should I try debian 11 as opposed to Jammy?
it looks like it is committed in 6.5 though thanks for your confirmation that it works!!! also turns out that your script doesn't like being run in a toolbox instance of ubuntu 22.04 . so nothing to be concerned about my last
@Igor Does this mean that 6.1.X kernel will now support MT7915E within 22.08? and I dont need to compile myself?
@Igor I am getting an error when using the compile.sh: /var/mnt/ubuntu/build/lib/functions/compilation/kernel-debs.sh: command substitution: line 282: syntax error near unexpected token `then' [💥] Exiting with error 2 [ at /var/mnt/ubuntu/build/lib/functions/compilation/kernel-debs.sh:1 in relationship to this section of code: if [[ "${script}" == "preinst" ]]; then cat <<- HOOK_FOR_REMOVE_VFAT_BOOT_FILES if is_boot_dev_vfat; then rm -f /boot/System.map* /boot/config* /boot/vmlinuz* /boot/$image_name /boot/uImage fi HOOK_FOR_REMOVE_VFAT_BOOT_FILES fi
@Igor - cant seem to register
I have updated the armbian-firmware to full package: root@rock-3a:/lib/firmware/mediatek# ls -la /lib/firmware/mediatek/ | grep mt7915 -rw-rw-r-- 1 root root 3584 Feb 17 22:23 mt7915_eeprom.bin -rw-rw-r-- 1 root root 3584 Feb 17 22:23 mt7915_eeprom_dbdc.bin -rw-rw-r-- 1 root root 144544 Feb 17 22:23 mt7915_rom_patch.bin -rw-rw-r-- 1 root root 116160 Feb 17 22:23 mt7915_wa.bin -rw-rw-r-- 1 root root 1260960 Feb 17 22:23 mt7915_wm.bin but my Mediatek 7915e seems to still be unsupported: root@rock-3a:/lib/firmware/mediatek# lspci 0000:00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3568 Remote Signal Processor (rev 01) 0000:01:00.0 Unclassified device [0002]: MEDIATEK Corp. MT7915E 802.11ax PCI Express Wireless Network Adapter 0002:00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3568 Remote Signal Processor (rev 01) Will I need to bake my own custom kernel using the compile script: https://docs.armbian.com/Developer-Guide_Build-Preparation/ I am running the following build and kernel: root@rock-3a:/lib/firmware/mediatek# uname -a Linux rock-3a 6.1.11-rk35xx #23.02.2 SMP PREEMPT Sat Feb 18 00:05:58 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux root@rock-3a:/lib/firmware/mediatek# cat /etc/os-release PRETTY_NAME="Armbian 23.02.2 Jammy" NAME="Ubuntu" VERSION_ID="22.04" VERSION="22.04 (Jammy Jellyfish)" VERSION_CODENAME=jammy ID=ubuntu ID_LIKE=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" PRIVACY_POLICY_URL="https://www.armbian.com" UBUNTU_CODENAME=jammy ARMBIAN_PRETTY_NAME="Armbian 23.08.0-trunk jammy" Support seems have been available since 5.10 kernel: https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/drivers/net/wireless/mediatek/mt76/mt7915/?h=v5.10.186 Any help would be appreciated
