25 -
As I had read, the maximum amount of RAM the H618 handles is 4GB, so, this 8GB TV Box should be a false information.
Hi dear @Nick A, I need your help to understand the branch to use in your repository, the main one is 20250306, but there are several branches that looks like more recent, like 20251226. May you explains what is more recent/better to use for an Transpeed M98?
Hi @Nick A, the armbian in afiftyp board just see 2GB to, at least it was this way in 2024 when he sent me his boot log. My board is very similar to afiftyp board, except of a number near the QC sticker, that looks like a version number. afiftyp number is 2336 and the mine is 2333. The amout of memory chips is identical to (8 chips), but tha labels is a litle different, but I cant found the label meaning. I use your image since very old one, so I don't think it is about u-boot update, but I could try an older one. About Secure Boot, A patch that you give me solved it and it isn't a problem any more (thanks again for it). @afiftyp, if I'm wrong and you already solve your rom amount in armbian, please let us know and if you could, explain us what you did to solve it, thanks.
Hi @kazekami_him, Thanks for your information, but I have no idea in how to use this content for test it. Maybe @Nick A Could understand what this guy did and how to bring it to his port and help us to detect the correct ram amount.
Hi @Nick A, I really need your help to understand the way to change the 171-add-x98h-defconfig.patch. Firstly, I extracted the DRAM parameters, but there are 15 of them: DRAM parameters, DRAM parameters 1, ... DRAM parameters E. Some of them have distinct parameters. The first of then (DRAM parameters) have the very identical parameters as yours, only differ in the same parameters, that isn't in patch file like TPR13, but I don't know if it matters. So I tried using the DRAM parameters 1, which is the most different, with clock 600 instead of 648 and almost all parameters different, but it works the same way with the same 2GB of RAM. I think this is strange, because with so many differences, I expected the image would not work. Do you have any tips for giving me? My extracted parameters: ./sunxi-fw info -v ./image4.img @ 0: wty: PhoenixSuite image file header v3.0, 45 images, 1859 MB wty:sys_config.fex : 34908 bytes @ +0x000000b800 wty:board.fex : 1024 bytes @ +0x0000014400 wty:config.fex : 53248 bytes @ +0x0000014800 wty:split_xxxx.fex : 512 bytes @ +0x0000021800 wty:sys_partition.fex : 5601 bytes @ +0x0000021c00 wty:sunxi.fex : 71680 bytes @ +0x0000023400 wty:boot0_nand.fex : 61440 bytes @ +0x0000034c00 wty:boot0_sdcard.fex : 61440 bytes @ +0x0000043c00 wty:u-boot.fex : 917504 bytes @ +0x0000052c00 wty:u-boot-crash.fex : 37 bytes @ +0x0000132c00 wty:toc1.fex : 8 bytes @ +0x0000133000 wty:toc0.fex : 8 bytes @ +0x0000133400 wty:fes1.fex : 40160 bytes @ +0x0000133800 wty:boot_package.fex : 1294336 bytes @ +0x000013d800 wty:usbtool.fex : 154624 bytes @ +0x0000279800 wty:usbtool_crash.fex : 621056 bytes @ +0x000029f400 wty:aultools.fex : 166515 bytes @ +0x0000337000 wty:aultls32.fex : 152069 bytes @ +0x000035fc00 wty:cardtool.fex : 73728 bytes @ +0x0000385000 wty:cardscript.fex : 1899 bytes @ +0x0000397000 wty:sunxi_gpt.fex : 8192 bytes @ +0x0000397800 wty:sunxi_mbr.fex : 65536 bytes @ +0x0000399800 wty:dlinfo.fex : 16384 bytes @ +0x00003a9800 wty:arisc.fex : 6 bytes @ +0x00003ad800 wty:vmlinux.fex : 12444168 bytes @ +0x00003adc00 wty:boot-resource.fex : 7490560 bytes @ +0x0000f8c000 wty:Vboot-resource.fex : 4 bytes @ +0x00016b0c00 wty:env.fex : 131072 bytes @ +0x00016b1000 wty:Venv.fex : 4 bytes @ +0x00016d1000 wty:boot.fex : 67108864 bytes @ +0x00016d1400 wty:Vboot.fex : 4 bytes @ +0x00056d1400 wty:vendor_boot.fex : 33554432 bytes @ +0x00056d1800 wty:Vvendor_boot.fex : 4 bytes @ +0x00076d1800 wty:super.fex : 1806382676 bytes @ +0x00076d1c00 wty:Vsuper.fex : 4 bytes @ +0x0073185400 wty:misc.fex : 16777216 bytes @ +0x0073185800 wty:Vmisc.fex : 4 bytes @ +0x0074185800 wty:vbmeta.fex : 8192 bytes @ +0x0074185c00 wty:Vvbmeta.fex : 4 bytes @ +0x0074187c00 wty:vbmeta_system.fex : 4096 bytes @ +0x0074188000 wty:Vvbmeta_system.fex : 4 bytes @ +0x0074189000 wty:vbmeta_vendor.fex : 4096 bytes @ +0x0074189400 wty:Vvbmeta_vendor.fex : 4 bytes @ +0x007418a400 wty:dtbo.fex : 2097152 bytes @ +0x007418a800 wty:Vdtbo.fex : 4 bytes @ +0x007438a800 @ 542: boot0: Allwinner boot0 size: 61440 bytes eGON checksum matches: 0x505a301a DRAM parameters: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1f12 0x1f12 PARA0 : - - 0x1 PARA1 : 0x1f12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0001002 0 TPR2 : 0 0 0xc0001002 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f1107 0x2f1107 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0001002 0xeddc7665 0xeddc7665 TPR13 : 0 0x40 0x40 DRAM parameters 1: A64 H616 A133 DRAM clock : 600 600 600 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c1a 0x1c1a PARA0 : - - 0x1 PARA1 : 0x1c1a 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc000130a 0 TPR2 : 0 0 0xc000130a TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc000130a 0xeddc6554 0xeddc6554 TPR13 : 0 0x40 0x40 DRAM parameters 2: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters 3: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters 4: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters 5: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters 6: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters 7: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters 8: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters 9: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters A: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters B: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters C: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters D: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40 DRAM parameters E: A64 H616 A133 DRAM clock : 648 648 648 DRAM type : 0x3 0x3 0x3 ZQ value : 0x3030303 - - ODT enabled : 0xe0e0e0e 0x1 - DX ODT : - 0x3030303 0x3030303 DX DRI : - 0xe0e0e0e 0xe0e0e0e CA DRI : - 0x1c12 0x1c12 PARA0 : - - 0x1 PARA1 : 0x1c12 0x30fb 0x30fb PARA2 : 0x1 0 0 MR0 : 0x30fb 0x840 0x840 MR1 : 0 0x4 0x4 MR2 : 0x840 0x8 0x8 MR3 : 0x4 0 0 TPR0 : 0x8 0xc0000a05 0 TPR2 : 0 0 0xc0000a05 TPR6 : 0 0x33808080 0x33808080 TPR10 : 0 0x2f0006 0x2f0006 TPR11 : 0 0xddddcccc 0xddddcccc TPR12 : 0xc0000a05 0xeddc7564 0xeddc7564 TPR13 : 0 0x40 0x40
Sorry last message, need more test.
Ok, I think I got it. Tomorrow I will give a try, thanks. Mi box is the Transpeed M98 Plus by the way.
Ok, maybe I made a mistake before. I tried with an no secure-boot .img file and it give a long list of DRAM params and I put it in the file below. But I don't know What I can do with it... I will appreciate your help. Thanks. DRAM_Transpeed_M98txt
Thanks again @Nick A, I already did it, the file I got, cant understood well, and there are very low information about dram, just 3 params dram {phandle = <0x7a>;}; vcc-dram = <0x04>; dram = "/dram"; dtb.0.dts
Yes, maybe. There are a way to make a similar patch for kernel instread of u-boot? In Android, the boot logo show some parameters like DRAM_VCC, DRAM_CLK, Chip id, Param1, param2 and tpr113 , it helps? Tanks for your time. [626]HELLO! SBOOT is starting! [629]sboot commit : 4b34f2890a [632]set pll start [634]periph0 has been enabled [637]set pll end [641]unknow PMU [642]unknow PMU [646]PMU: AXP1530 [650]dram return write ok [653]board init ok [655]enable_jtag [656]DRAM BOOT DRIVE INFO: V0.651 [660]the chip id is 0x2000 [662]chip id check OK [684]DRAM_VCC set to 1500 mv [687]DRAM CLK =648 MHZ [689]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4) [697]Actual DRAM SIZE =4096 M [700]DRAM SIZE =4096 MBytes, para1 = 310b, para2 = 10000000, dram_tpr13 = 6041 [709]DRAM simple test OK. [711]rtc standby flag is 0x0, super standby flag is 0x0 [717]dram size =4096 [719]Use rtc to store dram tuning para [723][mmc]: mmc driver ver 2021-10-12 13:56 [727][mmc]: b mmc 2 bias 4 [735][mmc]: Wrong media type 0x0, but host sdc2, try mmc first [741][mmc]: ***Try MMC card 2*** [770][mmc]: RMCA OK! [773][mmc]: MMC 5.1 [775][mmc]: HSSDR52/SDR25 8 bit [778][mmc]: 50000000 Hz [780][mmc]: 119280 MB [782][mmc]: ***SD/MMC 2 init OK!!!*** [858]read toc1 from emmc 32800 sector [862]OLD version: 0.0 [864]NEW version: 0.0 [870]don't have rotpk, skip check [941]load rotpk hash [1204]load vbmeta_a-key hash [1207]load vbmeta_a hash [1214]load vbmeta_b-key hash [1217]load vbmeta_b hash [1220]monitor entry=0x48000000 [1223]uboot entry=0x4a000000 [1226]optee entry=0x48600000 [1229]opensbi entry=0x0 [1231]no need rotpk flag [1234]tunning data addr:0x4a0003e8 [1239]run out of boot0 NOTICE: BL3-1: v1.0(debug):54937d5 NOTICE: BL3-1: Built : 17:44:59, 2021-12-13 NOTICE: BL3-1 commit: 8 NOTICE: cpuidle init version V2.0 NOTICE: secure os exist MESSAGE: [0x0] TEE-CORE: OP-TEE version: 5c40397e #1 Tue Feb 2 07:45:37 UTC 2021 arm NOTICE: BL3-1: Preparing for EL3 exit to normal world NOTICE: BL3-1: Next image address = 0x4a000000 NOTICE: BL3-1: Next image spsr = 0x1d3 U-Boot 2018.07-gb99798b4 (Apr 04 2023 - 13:23:26 +0000) Allwinner Technology [01.302]CPU: Allwinner Family [01.305]Model: sun50iw9 I2C: ready [01.313]DRAM: 4 GiB [01.322]Relocation Offset is: 70ecd000 [01.358]secure enable bit: 1 [01.360]smc_tee_inform_fdt failed with: ffffffff [01.365]pmu_axp152_probe pmic_bus_read fail [01.369]PMU: AXP1530 FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL [01.383]CPU=1416 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz
Yes, you already teach me how to make a patch to use secure boot and it works fine. Anyway, the ram patch didn't work. I build a new image now and it still shows only 2GB instead of 4GB. Maybe I miss a step to apply this patch?. The strange thing is that u-boot shows 4GB, than kernel shows 2GB in boot log. Even with a half of memory it works very well.
Hi @Nick A, sorry my late answer. I can't directly use your image, because my box is that boot-secure. I need to compile it every time I want to update, so my last build have about 4 months, but I think that time it just have a "new patch for dram" unless have a other new dram patch. Anyway, I'll try to build it again to try. If you have any additional tip to this, I'll appreciate. Thanks again for all your efforts.
@Alfi ciio, did you try to change the PRETTY_NAME on os-release file? It should be "Debian GNU/Linux 12 (bookworm)" to install HA Supervisor
Thanks @firepower, I have an Transpeed M98 with the same SP6330-X wifi-bluetooth chip and had the same problem as you had described. Now I just replace my original BCM4330B1.hcd by yours and now the Bluetooth worked like a charm. Now The only problem I still need to found a fix is my Ram memory that I just could use the half of 4GB that the box have.
Hi @Nick A. Sorry the late feedback, but I'm still test some things... Yes, I finally could boot Armbian with this image successfully. Almost everything worked fine Just Bluetooth and the memory size still bad. Desktop started OK; HDMI - image and sound - OK (Not in u-boot); Ethernet - OK; WIFI didn't work in beginning, because my chip is the sp6330, but I could make it to work following this tip: https://forum.armbian.com/topic/16696-armbian-for-tanix-tx3-amlogic-s905x3-with-sp6330-wifibluetooth-module/?do=findComment&comment=117066; Bluetooth still don't work. I see somewhere in this topic a tip about it, I'll look for it then; The box just recognize 2GB instead 4GB (In u-boot shows 4GB, but in system for some reason, just recognize 2GB); I could successfully install this image in internal EMMC with armbian-install and it works fine without the uSD inserted; Obs.: I cant update/upgrade the system, because it make the system stop working, so I freezed kernel upgrades and now I can update and upgrade without break the system. Thank for yours tips and efforts to help us.
