Urmas
  1. Hi guys I's possible to convert .bin file to text file. Could someone help me to do that. thank you
  2. Hi there, I have a problem with startup boot loader showing script when I added to the armbianConfig.txt file extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/1024x600.bin video=HDMI-A-1:1024x600@60 I lost boot startup loading script text on display - does not show anything until the desktop loaded. ones is desktop loaded it is very good resolution - want to keep that. but I need startup loading showing something image or startup loading text. Does anybody knowing how to do that?
  3. found easier display modifying commet out #setenv disp_mode "1024x600p60" mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr then set it armbianConfig.txt disp_mode "1024x600p60" extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/1024x600.bin video=HDMI-A-1:1024x600@60 in this way you be abele to change easily 5" and 7" lcd displays - just change the display resolution however the OS loading is still long time I understand drm_kms_helper generates the 1024x600.bin file but it does not save it or I just can't find it. Does anyone know where is it?
  4. I found the problem but I don't know how to get reed of it. booting to the desktop should start and then reboots the OS after that desktop works.
  5. 15.033s bootsplash-hide-when-booted.service 11.318s logrotate.service 5.116s snapd.service 4.652s armbian-ramlog.service 4.173s networkd-dispatcher.service 3.562s armbian-hardware-optimize.service 2.934s dev-loop5.device 2.921s dev-mmcblk0p1.device 2.409s armbian-zram-config.service 2.329s networking.service 1.999s systemd-random-seed.service 1.827s xrdp.service 1.768s fstrim.service 1.745s dev-loop4.device 1.743s dev-loop3.device 1.740s dev-zram0.device 1.620s apt-daily-upgrade.service 1.556s dev-loop1.device 1.537s snapd.seeded.service 1.464s dev-loop2.device 1.439s dev-loop0.device 1.438s NetworkManager.service 1.186s systemd-resolved.service 1.107s chrony.service 1.004s smartmontools.service 888ms ssh.service 876ms lightdm.service 852ms systemd-logind.service 852ms wpa_supplicant.service 834ms user@0.service 795ms loadcpufreq.service 787ms user@1000.service 769ms nfs-server.service 723ms systemd-udev-trigger.service 683ms proc-fs-nfsd.mount 677ms e2scrub_reap.service 638ms snapd.apparmor.service 626ms keyboard-setup.service 617ms alsa-restore.service 587ms apparmor.service 524ms dev-zram1.device 519ms systemd-udevd.service 477ms rpc-statd.service 475ms openvpn.service 467ms rc-local.service 467ms nfs-mountd.service 462ms hostapd.service 459ms rsyslog.service 448ms systemd-user-sessions.service 445ms sysstat.service 379ms dev-mqueue.mount 361ms sys-kernel-debug.mount 353ms sys-kernel-tracing.mount 352ms xrdp-sesman.service 338ms fake-hwclock.service 325ms kmod-static-nodes.service 309ms systemd-journald.service 309ms modprobe@drm.service 308ms modprobe@configfs.service 302ms modprobe@fuse.service 288ms systemd-rfkill.service 265ms systemd-tmpfiles-clean.service 265ms systemd-modules-load.service 244ms systemd-remount-fs.service 232ms resolvconf-pull-resolved.service 224ms plymouth-quit-wait.service 212ms cpufrequtils.service 202ms nfs-idmapd.service 189ms snap-bare-5.mount 182ms systemd-update-utmp.service 178ms snap-chromium-2058.mount 177ms modprobe@chromeos_pstore.service 164ms snap-core20-1615.mount 160ms armbian-led-state.service 156ms modprobe@mtdpstore.service 149ms snap-gnome\x2d3\x2d38\x2d2004-114.mount 148ms rpc-statd-notify.service 145ms dpkg-db-backup.service 142ms sysfsutils.service 139ms modprobe@efi_pstore.service 137ms snap-gtk\x2dcommon\x2dthemes-1535.mount 122ms dev-loop6.device 122ms polkit.service 121ms systemd-sysctl.service 117ms snap-snapd-16300.mount 115ms modprobe@pstore_blk.service 114ms sys-fs-fuse-connections.mount 111ms systemd-sysusers.service 107ms systemd-tmpfiles-setup.service 106ms run-rpc_pipefs.mount 104ms dev-loop7.device 104ms sys-kernel-config.mount 103ms tmp.mount 98ms rpcbind.service 90ms modprobe@pstore_zone.service 85ms ifupdown-pre.service 79ms console-setup.service 79ms modprobe@ramoops.service 78ms snap-gnome\x2d3\x2d38\x2d2004-117.mount 75ms setvtrgb.service 72ms plymouth-read-write.service 69ms nfs-blkmap.service 68ms user-runtime-dir@1000.service 67ms systemd-update-utmp-runlevel.service 63ms systemd-tmpfiles-setup-dev.service 61ms snap-chromium-2079.mount 60ms user-runtime-dir@0.service 57ms sysstat-collect.service 56ms snapd.socket 55ms armbian-hardware-monitor.service 53ms nfsdcld.service 43ms sysstat-summary.service 37ms systemd-journal-flush.service 16ms e2scrub_all.service
  6. Startup finished in 1min 5.125s (kernel) + 44.582s (userspace) = 1min 49.708s graphical.target reached after 21.382s in userspace
  7. sorry for not clarifying. once I have changed the boot.cmd and added to the armbianEnv.txt extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/1024x600.bin video=HDMI-A-1:1024x600@60 OS loading long time about 30s to 1min once it loaded then touchscreen and display works perfectly.
  8. for anyone have same problem 7" display what i did was changing boot script 1. modify file /boot/boot.cmd setenv disp_mode "1024x600p60" mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr but now I have another problem. It's loading long time can anybody help me with that?
  9. Hi guy's urgent help needed, I have banana pi m2 zero and I need the hdmi Waveshare 7inch LCD settings help. I have tried to change the config file also dts file, none of those worked. Tried to build with hdmi lcd (internet help) - none Could any one point out what is need to be done to get it work? thank you
