27 -
TV Box S912 (X9T 4K): problem to install on emmc
Antom replied to Nico059's topic in Amlogic CPU Boxes
Have the same issue, who has a ideas ? -
Okay, got it, will use Armbian now but my question is open. Is it possible to boot Armbian from USB ?
A have TVBOX on Amlogic S905l, but this tvbox don't have sdcard, is it possible to boot this board from armbian burned to USB, if yes, can someone share documentation ? I mean to boot from USB before booting from EMMC. I shorted the contacts on the board to disable emmc and I see this message in the TTL logs: GXL:BL1:9ac50e:bb16dc;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:800;NAND:81;SD:800;USB:8;LOOP:1;EMMC:800;NAND:81;SD:800;USB:8;LOOP:2;EMMC:800;NAND:81;SD:800;USB:8;LOOP:3;EMMC:0;READ:0;0.0;CHK:0; looks like chip is asking for USB, but I'm not sure that it can boot from Maybe I need to create a specific bootable USB? I used an image https://github.com/ophub/amlogic-s9xxx-armbian Link: https://github.com/ophub/amlogic-s9xxx-armbian/releases/download/Armbian_bookworm_save_2025.06/Armbian_25.08.0_amlogic_s905l-mg101_bookworm_6.12.31_server_2025.06.01.img.gz Please help me
Gxbaby "P200" tv box (MXQ PRO) does not boot
Antom replied to Abdellah B's topic in Amlogic CPU Boxes
have a problem with the same box how to boot from sdcard before boot from emmc ? as I know we need to run as update aml_autoscript file, but how to do that from armbian booted from sd card ? -
Thank you! it's really work! wow, my eMMC is dead, os sees the real size of eMMC, but R\W operations are not available. One more question, I have MX10 with an sv6051p wifi chip, but the os is not see any wifi devices, is it possible to turn on sv6051p chip?
wow, good news! just a small clarification, Do you mean pins that turn on maskrom mode? in my side on the other side of the board under emmc. Also another question, what about speed? i guess eMMC is better than sdcard?
one second, if i short the clock ping of eMMC, what are the next steps ? how to boot Armbian from sd card? just flash img to sd card, put it to box and it will boot from sd card ?
it looks like the bootloader is in stock because the multitool is loaded successfully, but I cant burn Armbian to emmc, it is stuck. How can I run Armbian from sdcard ?
One question about my bricked MX10 4\64 GB, is it possible to update by maskrom image of armbian ? i suspect that my mmc is dead, I got Download IDB Failed, one more question, is it possible to boot Armbian from SD CARD if mmc is dead?
Thank you so much! everything is clear for me. another question, where I can find the latest Legacy img ? i guess it is only Debian buster?
So, the case with updating UUID like Hqnicolas say won`t work?
Understood, but how to determine correct UUID ?
and how to determine my UUID ? new UUID
But how can i do it via `multitool.img.xz` ? I flash NAND from multitool.img.xz
mx4 pro I tried to write to nand archive/Armbian_24.2.5_Rk322x-box_jammy_current_6.6.22.img via multitool, and get this message Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enougth?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=b9866ace-f260-437c-9794-8e1a363a3c71 does not exist. Dropping to a shell. I guess only legacy images is work now, how to fix this problem, who can help?
