samond
  1. Well i found the solution for this suck settings....@Igor uhhh,It's a community release.......@SteeMan hope this could help someone else.... It seems like ssh port is ruled by sshd.socket rather than sshd.service.... So,we need add a sshd.socket @ `/etc/systemd/system` ``` [Socket] ListenStream= ListenStream=4200 ``` (the first ListenStream= is to disable the default 22) and then verify it `cat /etc/systemd/system/sshd.socket.d/override.conf` and then `systemctl daemon-reload` `systemctl enable sshd.socket` `systemctl start sshd.socket` check the status `systemctl status sshd.socket` ----------------------------- further more ,Some branches do not support sftp ,so... `sudo mkdir -p /etc/systemd/system/sshd@.service.d` `/etc/systemd/system/sshd@.service.d/sftp.conf` write this: ``` [Service] Environment="OPTIONS=-o Subsystem=\"sftp /usr/libexec/sftp-server\"" ``` `sudo systemctl daemon-reload`
  2. Hi, everyone, Recently, i found i can't change ssh port on 6.4.16 bookworm (Onecloud) cli version(https://github.com/armbian-delta/os/releases/download/23.8.0-trunk.2/Armbian_23.8.0-trunk.2_Onecloud_bookworm_edge_6.4.16.img.xz#onecloud) i changed the `/etc/ssh/sshd_config` add the `Port 10086` .and then i restart the system, It still not working, ssh port only work on `22` but at the same time, i found the other thing `KexAlgorithms curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1` i added is working. So, i check if selinux is disabled, the sestatus says it's disabled. and check the sshd status...it stills on port 22, no 10086 `root@onecloud:~# service sshd status ● ssh.service - OpenBSD Secure Shell server Loaded: loaded (/lib/systemd/system/ssh.service; enabled; preset: enabled) Active: active (running) since Thu 2023-10-12 14:15:38 CST; 3s ago TriggeredBy: ● ssh.socket Docs: man:sshd(8) man:sshd_config(5) Process: 7609 ExecStartPre=/usr/sbin/sshd -t (code=exited, status=0/SUCCESS) Main PID: 7610 (sshd) Tasks: 1 (limit: 2190) Memory: 1.0M CPU: 305ms CGroup: /system.slice/ssh.service └─7610 "sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups" Oct 12 14:15:38 onecloud systemd[1]: Starting ssh.service - OpenBSD Secure Shel> Oct 12 14:15:38 onecloud sshd[7610]: Server listening on :: port 22. Oct 12 14:15:38 onecloud systemd[1]: Started ssh.service - OpenBSD Secure Shell` So i checked `netstat -atunlp | grep sshd` there is only 22.. ` tcp6 0 0 192.168.1.112:22 xxx:20158 ESTABLISHED 3147/sshd: root@pts tcp6 0 144 192.168.1.112:22 xxx:22320 ESTABLISHED 3514/sshd: root@pts ` iptables nothing on it. `Chain INPUT (policy ACCEPT) target prot opt source destination Chain FORWARD (policy ACCEPT) target prot opt source destination Chain OUTPUT (policy ACCEPT) target prot opt source destination` So, it may be a bug, sshd can't read configuration to open a new port?
