Malbonulo
  1. I just created a pull request for this. Apologies if I got the request wrong, it's been a long time since I created a PR on anything.
  2. Although they're in my file (I have used armbian for a long time so it might be legacy code) they do not run because they are in a test that returns false. I think you have the important part which is # this is for mainline only if test "${board_name}" = "xu4"; then setenv fdtfile "exynos5422-odroidxu4.dtb"; fi if test "${board_name}" = "xu3"; then setenv fdtfile "exynos5422-odroidxu3.dtb"; fi if test "${board_name}" = "xu3l"; then setenv fdtfile "exynos5422-odroidxu3-lite.dtb"; fi if test "${board_name}" = "hc1"; then setenv fdtfile "exynos5422-odroidhc1.dtb"; fi # legacy shares a single DT for all boards if ext4load mmc 0:1 0x00000000 "/boot/.next" || fatload mmc 0:1 0x00000000 ".next" || ext4load mmc 0:1 0x00000000 ".next"; then echo "Found mainline kernel configuration"; else setenv fdtfile "exynos5422-odroidxu3.dtb"; fi ext4load mmc 0:1 0x44000000 /boot/dtb/${fdtfile} || fatload mmc 0:1 0x44000000 dtb/${fdtfile} || ext4load mmc 0:1 0x44000000 dtb/${fdtfile} Although I'm no expert.
  3. It's been a while since I coded in bash but I'll take a look. I see the necessary line in the motd is taken from /etc/armbian-image-release and then these values are over-written from /etc/armbian-release The variable in question is BOARD_NAME. I guess it would be a simple matter to rewrite BOARD_NAME=..., I just wouldn't know if this had a knock-on effect down the line somewhere. Having said all this, this is all just cosmetic, the important change will be to /boot/armbianEnv.txt where the line board_name= needs to change, this is what sets the correct dtb in boot.ini. But it strikes me that even if I send a pull request, that will take someone's time, and if you can't support an hour, maybe the pull request is not worth it?
  4. Thank-you. > Aha, you mean you miss this: Yes! Why was it removed? > You need to edit /boot/boot.ini and add / replace it in this line: > setenv overlays "i2c0 i2c1 hktft-cs-ogst That line was already in the file > Also there is a problem here: > ext4load mmc 0:1 0x60000000 /boot/dtb/overlays/${overlay}.dtbo Ok, but to change the filepath to /boot/dtb/${overlay}.dtbo, I would need to put the .dtbo files back into /boot/dtb/, right?
  5. Thanks. I followed your instructions, and selected every overlay in the list, then rebooted. The motd is still saying it's an XU4 board. /_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v24.11.1 for Odroid XU4 running Armbian Linux 6.6.60-current-odroidxu4 I also have /boot/armbianEnv.txt: line 2: hktft35: command not found when saving these options in armbian-config. # cat /boot/armbianEnv.txt board_name=hc1 fdt_overlays=ads7846 hktft32 hktft35 hktft-cs-ogst i2c0 i2c1 onewire spi0 sx865x-i2c1 uart0 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u # ls /boot/dtb/overlay/ ads7846.dtbo hktft35.dtbo i2c0.dtbo onewire.dtbo sx865x-i2c1.dtbo hktft32.dtbo hktft-cs-ogst.dtbo i2c1.dtbo spi0.dtbo uart0.dtbo
  6. I've been running Armbian on an Odroid HC1 board for some time now. We've just had a kernel upgrade and it now boots as an XU4 according to the motd. This used to be changeable with armbian-config (I did this regularly on kernel updates). But, with the new armbian-config I can't find a way to do this any more. *edit A bit more info Running SY017 in armbian-config gives an empty list, and I get this error: ls: cannot access '/boot/dtb/overlay/*.dtbo': No such file or directory In fact /boot/dtb/overlay/ does not exist
