Prax
  1. Which GUI are you using? I deinstalled xrdp and Im using gnome remote desktop without problems now.
  2. Great, ordered one
  3. Im just an idiot ... tried to connect while no display was connected. If I just connect a display there is no problem. Is there any option to use rdp or vnc without a attached display?
  4. Yes I set all of this and updated the package. Think it was xrdp but removing it and rebooting didnt fixed it.
  5. xrdp was still enabled from armbian-config. I disabled and remove xrdp. Now I just cant login... getting an error from gnome-remote-desktop on the orangepi5 Feb 23 20:32:29 orangepi5 gnome-remote-desktop-daemon[6118]: Cannot load libcuda.so.1 Feb 23 20:32:29 orangepi5 gnome-remote-desktop-daemon[6118]: Cannot load libnvidia-encode.so.1
  6. I activated it by gui but I can't connect. Do I have to log off with the user before I can login remote? Edit: When I log off localy I can connect but I get a black screen and get disconnected after like 10 seconds
  7. Tried with mstsc and with vnc can't connect. When I check grdctl status there isn't any credentials set while they are set in the ui. I also can't set credentials using grdctl, getting the error: "Cannot create an item in a locked collection" If I try to connect: VNC literally nothing happens client hangs trying to connect RDP I get asked for credentials, afterwards I have to confirm the cert and then it closes suddenly without a error.
  8. It is installed and I enabled it but I cant connect. Is there any config I have to do to use it?
  9. That fixed the problem. Thanks a lot! Now I only have to find a option to remote connect using wayland instead of x11.
  10. I will try that tomorrow, thanks!
  11. While installing the first .deb I still get the same errors as mentioned above when reinstalling. While installing the second .deb I get a ton of warning and errors that used functions are deprecated. Thanks for your help, can't say it often enough! Here are the cat of anbox-binder and anbox-ashmen. Cat of /var/lib/dkms/anbox-binder/1/build/make.log is following: DKMS make.log for anbox-binder-1 for kernel 5.10.110-rockchip-rk3588 (aarch64) Mi 22. Feb 22:22:42 CET 2023 make -C /lib/modules/5.10.110-rockchip-rk3588/build V=0 M=$PWD make[1]: Entering directory '/usr/src/linux-headers-5.10.110-rockchip-rk3588' CC [M] /var/lib/dkms/anbox-binder/1/build/deps.o CC [M] /var/lib/dkms/anbox-binder/1/build/binder.o CC [M] /var/lib/dkms/anbox-binder/1/build/binder_alloc.o CC [M] /var/lib/dkms/anbox-binder/1/build/binderfs.o In file included from ././include/linux/kconfig.h:7, from <command-line>: ./include/generated/autoconf.h:1720: warning: "CONFIG_ANDROID_BINDER_DEVICES" redefined error, forbidden warning:autoconf.h:1720 1720 | #define CONFIG_ANDROID_BINDER_DEVICES "binder,hwbinder,vndbinder,anbox-binder,anbox-hwbinder,anbox-vndbinder" | <command-line>: note: this is the location of the previous definition In file included from ././include/linux/kconfig.h:7, from <command-line>: ./include/generated/autoconf.h:2246: warning: "CONFIG_ANDROID_BINDERFS" redefined error, forbidden warning:autoconf.h:2246 2246 | #define CONFIG_ANDROID_BINDERFS 1 | <command-line>: note: this is the location of the previous definition /var/lib/dkms/anbox-binder/1/build/deps.c:20:3: error: #error "Your kernel does not support KProbes, but this is required to compile binder as a kernel module on kernel 5.7 and later" 20 | # error "Your kernel does not support KProbes, but this is required to compile binder as a kernel module on kernel 5.7 and later" | ^~~~~ make[2]: *** [scripts/Makefile.build:273: /var/lib/dkms/anbox-binder/1/build/deps.o] Error 1 make[2]: *** Waiting for unfinished jobs.... In file included from ././include/linux/kconfig.h:7, from <command-line>: ./include/generated/autoconf.h:1720: warning: "CONFIG_ANDROID_BINDER_DEVICES" redefined error, forbidden warning:autoconf.h:1720 1720 | #define CONFIG_ANDROID_BINDER_DEVICES "binder,hwbinder,vndbinder,anbox-binder,anbox-hwbinder,anbox-vndbinder" | <command-line>: note: this is the location of the previous definition In file included from ././include/linux/kconfig.h:7, from <command-line>: ./include/generated/autoconf.h:2246: warning: "CONFIG_ANDROID_BINDERFS" redefined error, forbidden warning:autoconf.h:2246 2246 | #define CONFIG_ANDROID_BINDERFS 1 | <command-line>: note: this is the location of the previous definition /var/lib/dkms/anbox-binder/1/build/binder.c: In function 'binder_translate_binder': /var/lib/dkms/anbox-binder/1/build/binder.c:2456:49: error: passing argument 1 of 'security_binder_transfer_binder' from incompatible pointer type [-Werror=incompatible-pointer-types] 2456 | if (security_binder_transfer_binder(proc->tsk, target_proc->tsk)) { | ~~~~^~~~~ | | | struct task_struct * In file included from /var/lib/dkms/anbox-binder/1/build/binder.c:63: ./include/linux/security.h:258:56: note: expected 'const struct cred *' but argument is of type 'struct task_struct *' 258 | int security_binder_transfer_binder(const struct cred *from, | ~~~~~~~~~~~~~~~~~~~^~~~ /var/lib/dkms/anbox-binder/1/build/binder.c:2456:67: error: passing argument 2 of 'security_binder_transfer_binder' from incompatible pointer type [-Werror=incompatible-pointer-types] 2456 | if (security_binder_transfer_binder(proc->tsk, target_proc->tsk)) { | ~~~~~~~~~~~^~~~~ | | | struct task_struct * In file included from /var/lib/dkms/anbox-binder/1/build/binder.c:63: ./include/linux/security.h:259:56: note: expected 'const struct cred *' but argument is of type 'struct task_struct *' 259 | const struct cred *to); | ~~~~~~~~~~~~~~~~~~~^~ /var/lib/dkms/anbox-binder/1/build/binder.c: In function 'binder_translate_handle': /var/lib/dkms/anbox-binder/1/build/binder.c:2506:49: error: passing argument 1 of 'security_binder_transfer_binder' from incompatible pointer type [-Werror=incompatible-pointer-types] 2506 | if (security_binder_transfer_binder(proc->tsk, target_proc->tsk)) { | ~~~~^~~~~ | | | struct task_struct * In file included from /var/lib/dkms/anbox-binder/1/build/binder.c:63: ./include/linux/security.h:258:56: note: expected 'const struct cred *' but argument is of type 'struct task_struct *' 258 | int security_binder_transfer_binder(const struct cred *from, | ~~~~~~~~~~~~~~~~~~~^~~~ /var/lib/dkms/anbox-binder/1/build/binder.c:2506:67: error: passing argument 2 of 'security_binder_transfer_binder' from incompatible pointer type [-Werror=incompatible-pointer-types] 2506 | if (security_binder_transfer_binder(proc->tsk, target_proc->tsk)) { | ~~~~~~~~~~~^~~~~ | | | struct task_struct * In file included from /var/lib/dkms/anbox-binder/1/build/binder.c:63: ./include/linux/security.h:259:56: note: expected 'const struct cred *' but argument is of type 'struct task_struct *' 259 | const struct cred *to); | ~~~~~~~~~~~~~~~~~~~^~ /var/lib/dkms/anbox-binder/1/build/binder.c: In function 'binder_translate_fd': /var/lib/dkms/anbox-binder/1/build/binder.c:2598:49: error: passing argument 1 of 'security_binder_transfer_file' from incompatible pointer type [-Werror=incompatible-pointer-types] 2598 | ret = security_binder_transfer_file(proc->tsk, target_proc->tsk, file); | ~~~~^~~~~ | | | struct task_struct * In file included from /var/lib/dkms/anbox-binder/1/build/binder.c:63: ./include/linux/security.h:260:54: note: expected 'const struct cred *' but argument is of type 'struct task_struct *' 260 | int security_binder_transfer_file(const struct cred *from, | ~~~~~~~~~~~~~~~~~~~^~~~ /var/lib/dkms/anbox-binder/1/build/binder.c:2598:67: error: passing argument 2 of 'security_binder_transfer_file' from incompatible pointer type [-Werror=incompatible-pointer-types] 2598 | ret = security_binder_transfer_file(proc->tsk, target_proc->tsk, file); | ~~~~~~~~~~~^~~~~ | | | struct task_struct * In file included from /var/lib/dkms/anbox-binder/1/build/binder.c:63: ./include/linux/security.h:261:54: note: expected 'const struct cred *' but argument is of type 'struct task_struct *' 261 | const struct cred *to, struct file *file); | ~~~~~~~~~~~~~~~~~~~^~ /var/lib/dkms/anbox-binder/1/build/binder.c: In function 'binder_transaction': /var/lib/dkms/anbox-binder/1/build/binder.c:3001:53: error: passing argument 1 of 'security_binder_transaction' from incompatible pointer type [-Werror=incompatible-pointer-types] 3001 | if (security_binder_transaction(proc->tsk, | ~~~~^~~~~ | | | struct task_struct * In file included from /var/lib/dkms/anbox-binder/1/build/binder.c:63: ./include/linux/security.h:256:52: note: expected 'const struct cred *' but argument is of type 'struct task_struct *' 256 | int security_binder_transaction(const struct cred *from, | ~~~~~~~~~~~~~~~~~~~^~~~ /var/lib/dkms/anbox-binder/1/build/binder.c:3002:60: error: passing argument 2 of 'security_binder_transaction' from incompatible pointer type [-Werror=incompatible-pointer-types] 3002 | target_proc->tsk) < 0) { | ~~~~~~~~~~~^~~~~ | | | struct task_struct * In file included from /var/lib/dkms/anbox-binder/1/build/binder.c:63: ./include/linux/security.h:257:52: note: expected 'const struct cred *' but argument is of type 'struct task_struct *' 257 | const struct cred *to); | ~~~~~~~~~~~~~~~~~~~^~ /var/lib/dkms/anbox-binder/1/build/binder.c: In function 'binder_ioctl_set_ctx_mgr': /var/lib/dkms/anbox-binder/1/build/binder.c:4956:51: error: passing argument 1 of 'security_binder_set_context_mgr' from incompatible pointer type [-Werror=incompatible-pointer-types] 4956 | ret = security_binder_set_context_mgr(proc->tsk); | ~~~~^~~~~ | | | struct task_struct * In file included from /var/lib/dkms/anbox-binder/1/build/binder.c:63: In file included from ././include/linux/kconfig.h:7, from <command-line>: ./include/generated/autoconf.h:1720: warning: "CONFIG_ANDROID_BINDER_DEVICES" redefined error, forbidden warning:autoconf.h:1720 1720 | #define CONFIG_ANDROID_BINDER_DEVICES "binder,hwbinder,vndbinder,anbox-binder,anbox-hwbinder,anbox-vndbinder" | <command-line>: note: this is the location of the previous definition In file included from ././include/linux/kconfig.h:7, from <command-line>: ./include/generated/autoconf.h:2246: warning: "CONFIG_ANDROID_BINDERFS" redefined error, forbidden warning:autoconf.h:2246 2246 | #define CONFIG_ANDROID_BINDERFS 1 | <command-line>: note: this is the location of the previous definition make[2]: *** [scripts/Makefile.build:273: /var/lib/dkms/anbox-binder/1/build/binderfs.o] Error 1 make[2]: *** Deleting file '/var/lib/dkms/anbox-binder/1/build/binderfs.o' In file included from ././include/linux/kconfig.h:7, from <command-line>: ./include/generated/autoconf.h:1720: warning: "CONFIG_ANDROID_BINDER_DEVICES" redefined error, forbidden warning:autoconf.h:1720 1720 | #define CONFIG_ANDROID_BINDER_DEVICES "binder,hwbinder,vndbinder,anbox-binder,anbox-hwbinder,anbox-vndbinder" | <command-line>: note: this is the location of the previous definition In file included from ././include/linux/kconfig.h:7, from <command-line>: ./include/generated/autoconf.h:2246: warning: "CONFIG_ANDROID_BINDERFS" redefined error, forbidden warning:autoconf.h:2246 2246 | #define CONFIG_ANDROID_BINDERFS 1 | <command-line>: note: this is the location of the previous definition make[2]: *** [scripts/Makefile.build:273: /var/lib/dkms/anbox-binder/1/build/binder_alloc.o] Error 1 make[2]: *** Deleting file '/var/lib/dkms/anbox-binder/1/build/binder_alloc.o' ./include/linux/security.h:255:56: note: expected 'const struct cred *' but argument is of type 'struct task_struct *' 255 | int security_binder_set_context_mgr(const struct cred *mgr); | ~~~~~~~~~~~~~~~~~~~^~~ cc1: some warnings being treated as errors make[2]: *** [scripts/Makefile.build:273: /var/lib/dkms/anbox-binder/1/build/binder.o] Error 1 make[1]: *** [Makefile:1920: /var/lib/dkms/anbox-binder/1/build] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-5.10.110-rockchip-rk3588' make: *** [Makefile:8: all] Error 2 Cat of /var/lib/dkms/anbox-ashmem/1/build/make.log is following: DKMS make.log for anbox-ashmem-1 for kernel 5.10.110-rockchip-rk3588 (aarch64) Mi 22. Feb 22:22:37 CET 2023 make -C /lib/modules/5.10.110-rockchip-rk3588/build V=0 M=$PWD make[1]: Entering directory '/usr/src/linux-headers-5.10.110-rockchip-rk3588' CC [M] /var/lib/dkms/anbox-ashmem/1/build/deps.o CC [M] /var/lib/dkms/anbox-ashmem/1/build/ashmem.o /var/lib/dkms/anbox-ashmem/1/build/deps.c:9:3: error: #error "Your kernel does not support KProbes, but this is required to compile ashmem as a kernel module on kernel 5.7 and later" 9 | # error "Your kernel does not support KProbes, but this is required to compile ashmem as a kernel module on kernel 5.7 and later" | ^~~~~ make[2]: *** [scripts/Makefile.build:273: /var/lib/dkms/anbox-ashmem/1/build/deps.o] Error 1 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [Makefile:1920: /var/lib/dkms/anbox-ashmem/1/build] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-5.10.110-rockchip-rk3588' make: *** [Makefile:12: all] Error 2
  12. Switched to nightly build. Binder and Ashmem are now activated in the config (/boot/config-5.10.110-rockchip-rk3588) but while kernel installation and at every reinstall I still get these errors: Building module: cleaning build area... make -j8 KERNELRELEASE=5.10.110-rockchip-rk3588 all KERNEL_SRC=/lib/modules/5.10.110-rockchip-rk3588/build....(bad exit status: 2) Error! Bad return status for module build on kernel: 5.10.110-rockchip-rk3588 (aarch64) Consult /var/lib/dkms/anbox-ashmem/1/build/make.log for more information. Kernel preparation unnecessary for this kernel. Skipping... Building module: cleaning build area... make -j8 KERNELRELEASE=5.10.110-rockchip-rk3588 all KERNEL_SRC=/lib/modules/5.10.110-rockchip-rk3588/build.....(bad exit status: 2) Error! Bad return status for module build on kernel: 5.10.110-rockchip-rk3588 (aarch64) Consult /var/lib/dkms/anbox-binder/1/build/make.log for more information. So I not only get them when I try to install the modules using dkms. I also get them when I reinstall the kernel. /var/lib/dkms/anbox-binder/1/build/make.log gives following error: "Your kernel does not support KProbes, but this is required to compile ashmem as a kernel module on kernel 5.7 and later"
  13. Tried that. Getting the following error:"Reinstallation of linux-image-legacy-rockchip-rk3588 is not possible, it cannot be downloaded" Also tried updating the dependecies and to reinstall using aptitude. Error there is:"Cant find source to download version '23.02.0-trunk.0184' of 'linux-image-legacy-rockchip-rk3588' Any idea on how to reinstall?
  14. ahsmem and binder are not set. Should be a good chance then to get it working if I rebuild the kernel. Gonna try that tomorrow. Thanks a lot! Edit: Can I just copy this config, set the needed values and rebuild the kernel with it?
  15. Apt sais I already have the newest version. Dkms install still doesnt work. So I think I have to build one myself?
