dokw
  1. The one on fi.mirror.armbian.de should be the most recent. On other mirrors, the most recent linux-u-boot-odroidc2-current has a timestamp of 2024-02-29. At the least, these mirros are all out-of-date: mirrors.jevincanders.net, armbian.tnahosting.net, mirror.dotsrc.org, armbian.lv.auroradev.org, au.sbcmirror.org, armbian.hosthatch.com
  2. armbian-bsp-cli-odroidc2_24.2.1_arm64__1-PC13d1-Vf2bb-H02fb-Ba537-R6632.deb is available in the package list but the actual .deb file is missing on the server, which causes apt upgrade to fail with HTTP 404. This happens to lots of mirrors.
  3. Hello, I have trouble activating i2c on odroid c4. There's a pcf8563 module connected to the board. Also, /dev/i2c-0 /dev/i2c-1 exist. But pcf8563 does not show up when I run i2cdetect. I can rule out hardware issue because both i2c and pcf8563 work well with Hardkernel's Ubuntu image. So far, I've tried the followings but they don't work: Adding overlay="i2cA i2cB" to /boot/armbianEnv.txt and reboot. Manually editing device tree by changing status under "i2c@1d000" to "okay" and reboot. Also, I remember that i2c used to work on older versions of Armbian, which come with older version of kernels. But since linux 5.19, i2c no longer works. So I suspect that some changes in kernel may break the i2c functionality. I've uploaded diagnose info to https://paste.armbian.com/pevijojiwa Please advise. Thank you.
