Maybe we can bundle our effords regarding a working S805 image?
I also have hundreds of new TV sticks (not boxes) with an Amlogic S805 (Meson 8B). The original Android ROM has the codename stvm8b. Currently I only have a working Android 4.2.2 image with a patched kernel for real 1080p output which can be flashed using TWRP onto the internal eMMC.
I really would love to get some kind of more recent and non-Android image up and running. It's a real struggle to get any custom images as most links are dead already which makes it more complicated.
Currently I have full UART access to the device and I'm able to interact with the uBoot shell. I also see the full kernel output of the working Android image and have a root shell there. But as others already pointed out kernel 3.10 is way to old to be used in production. So "porting" a more recent kernel would be great.
My main goal is to get a Linux image up and running on the box which makes it still useful as device for digital signage or as a small webserver.
Some more details on the hardware:
ro.product.name=stvm8b
ro.product.device=stvm8b
ro.product.board=stvm8b
ro.product.cpu.abi=armeabi-v7a
ro.board.platform=meson8
uBoot output dropping to shell:
QA5:A;SVN:B72;POC:1FF;STS:0;BOOT:0;INIT:0;READ:0;CHECK:0;PASS:0;
no sdio debug board detected
TE : 76654
BT : 15:34:06 May 13 2015
##### VDDEE voltage = 0x044c
CPU clock is 792MHz
DDR mode: 32 bit mode
DDR size: 1GB (auto)
DDR check: Pass!
DDR clock: 636MHz with 2T mode
DDR pll bypass: Disabled
DDR init use : 14831 us
HHH
Boot From SDIO C
SD_boot_type: 00000002
card_type: 00000003
0x0000009f
ucl decompress...pass
0x12345678
Boot from internal device 1st eMMC on SDIO C
TE : 301370
System Started
U-Boot Version: 2011.03-ad3b84b(20150513.153356)
clr h-ram
DRAM: 1 GiB
relocation Offset is: 2feb4000
show partition table:
part: 0, name : logo, size : 2000000
part: 1, name : recovery, size : 2000000
part: 2, name : misc, size : 2000000
part: 3, name : boot, size : 2000000
part: 4, name : system, size : 40000000
part: 5, name : cache, size : 20000000
part: 6, name : backup, size : 20000000
part: 7, name : data, size : end
aml_card_type=0x0
MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6
[mmc_register] add mmc dev_num=1, port=2, if_type=6
SDIO Port B: 0, SDIO Port C: 1
power init
out reg=c110804c,value=dfffffff
IR init done!
register usb cfg[0][1] = 3ff6c19c
register usb cfg[0][2] = 3ff6c184
NAND: EMMC BOOT: not init nand
do not init nand : cause boot_device_flag without nand
get_boot_device_flag: init_ret -1
get_boot_device_flag EMMC BOOT:
Emmckey: Access range is illegal!
[mmc_init] SDIO Port C:1, if_type=7, initialized OK!
[mmc_get_partition_table] skip cache partition.
Partition table get from SPL is :
name offset size flag
0: bootloader 0 400000 0
1: reserved 2400000 4000000 0
2: cache 6c00000 20000000 2
3: env 27400000 800000 0
4: logo 28400000 2000000 1
5: recovery 2ac00000 2000000 1
6: misc 2d400000 2000000 1
7: boot 2fc00000 2000000 1
8: system 32400000 40000000 1
9: backup 72c00000 20000000 1
10: data 93400000 13ec00000 4
mmc read lba=0x12000, blocks=0x1
mmc read lba=0x12001, blocks=0x1
mmc_read_partition_tbl: mmc read partition OK!
eMMC/TSD partition table have been checked OK!
i=0,register --- emmc_key
MMC BOOT, emmc_env_relocate_spec : env_relocate_spec 59
set_storage_device_flag: store 2
bad chip version!!!
efuse mac is : ac:db:da:3d:c4:e5
set ethaddr is : ac:db:da:3d:c4:e5
usid is MH0507015420365
mmc flash is used high freq
info->dtbversion = 1025
boardname=stvm8b
boardtype=m8b_dongle
wifi=rtl8189es
dtbtype=stvm8b_dongle_1g
Multi dtb tool version: v2 .
Multi dtb detected, support 5 dtbs.
aml_dt soc: stvm8b platform: dongle variant: 1g
dtb 0 soc: stvm8b plat: dongle vari: 1g
dtb 1 soc: stvm8b plat: dongle vari: 512m
dtb 2 soc: stvm8b plat: normal vari: 1g
dtb 3 soc: stvm8b plat: normal vari: 1gcm
dtb 4 soc: stvm8b plat: normal vari: 512mcm
Find match dtb: 0
vpu clk_level in dts: 3
set vpu clk: 182150000Hz, readback: 182150000Hz(0x701)
Net: Meson_Ethernet
init suspend firmware done. (ret:0)
cvbs trimming.1.v5: 0xa0, 0x0
preboot new...
check board version...
bad chip version!!!
boardname=stvm8b
wifi=rtl8189es
Hardware version information has been written and the check is successful
hdmi tx power init
mode = 8 vic = 16
set HDMI vic: 16
mode is: 8
viu chan = 1
config HPLL
config HPLL done
reconfig packet setting done
Hit Enter key to stop autoboot -- : 1 tstc enter
exit abortboot: 1
The original name was "MyGica ATV185" and each device has a Quad-Core processor (Cortex A5, 1 GHz), 1 GB RAM, 8 GB internal eMMC storage, a WIFI module, 1x USB2.0, 1x microSD slot, 1x HDMI plug and 1x microUSB as power supply.
The device should be the same like the ODroid C1
Would love to participate in the process of creating a useful image for the S805 platform and especially for this piece of hardware.
