_Rygelius_
  1. fdisk -l /dev/nvme0n1 Disk /dev/nvme0n1: 238,47 GiB, 256060514304 bytes, 500118192 sectors Disk model: SK hynix BC501 HFM256GDJTNG-8310A Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes It's a Gen 3 device, throughputs using iozone3 (or simply dd for a sequential write test) are normal (on wintendo levels) I tried mounted and not mounted, with a 100% percent partion in default "linux file system" (ext4) and (v)fat(32), to no avail, it's always coming up with its complaint about no free space on the device
  2. Hey there, first of all: THANKS for the armbian project! My issue is with an M1, fresh jammy xfce install on an sd-card. NVME is installed (can be accessed after mounting it manually, no issues there) Wishing to move system to this /dev/nvme0n1, keeping boot on the sdcard, as I understand this being the only viable option, currently. When using armbian-install, selectin option 1 "Boot from SD - system on SATA, USB or NVMe" and confiming, next is an error message: --- There is not enough free capacity on /dev/nvme0n1. Please check your device. --- Did so, tried creating an empty (linux) file system, fat etc, accessible using mount, still the same error. I am pretty sure I am doing something wrong and I'm missing something completely, could someone please help me out? Thanks so much 🙂
