nairaca_10
  1. I already compile and install the driver. Now I got another problem, and yes, its about my comment above. When I run inxi -Nn on terminal, the driver is still usb-storage so the wifi dongle cant use the driver I just install, and I dont know how to solve this.
  2. Thank you so much!
  3. Thank you for the reply Werner! At this point, Im still compiling it. Will mark it as a solution if it works! Currently, when I run inxi -Nn on terminal, it shows that the device driver is usb storage (Ill comment an update for this also)
  4. Hi, Im using orangepi pc with armbian jammy. On download section there is only 2 choices, CLI and Desktop. Is there a custom desktop version where most (or if possible all) applications are not installed? It would take too long is I uninstall it one by one. I think I only need browser and terminal.
  5. Hi!, I just bought my orangepi pc and also installed Armbian desktop. I also bought a wifi dongle with rtl8188gu chip. Is there any steps on how to use this to connect to my network?
