Marco d_Itri
  1. I think that the simplest way for you would be to download the older Armbian image with the older u-boot version, USB-boot it and then use the two dd commands to install u-boot on you actual boot device. Or else just download it on your board, loopback-mount it and copy the file with dd from there.
  2. Yes: on my blog post you fill find the exact commands you need to install u-boot taken from an older image. https://blog.bofh.it/debian/id_466
  3. u-boot from Armbian_23.02.0-trunk_Bananapim5_sid_edge_6.2.0-rc3_minimal.img hangs if I try to boot with my USB hard disk connected. I replaced it with u-boot from Armbian_22.08.7_Bananapim5_bullseye_edge_5.19.16.img and that one works fine. U-Boot 2022.10-armbian (Feb 12 2023 - 17:20:43 +0000)bpi-m5 Model: Banana Pi BPI-M5 SoC: Amlogic Meson SM1 (S905X3) Revision 2b:c (10:2) DRAM: 3.8 GiB Core: 384 devices, 27 uclasses, devicetree: separate MMC: sd@ffe05000: 0, mmc@ffe07000: 1 Loading Environment from nowhere... OK In: serial Out: serial Err: serial Net: eth0: ethernet@ff3f0000 Autoboot in 2 seconds starting USB... Bus usb@ff500000: Register 3000140 NbrPorts 3 Starting the controller USB XHCI 1.10 scanning bus usb@ff500000 for devices... error in inquiry If I unplug the USB hard disk then also the newer u-boot works fine: scanning bus usb@ff500000 for devices... 4 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found
