armsom-jackson
  1. Hello, we have tried wifi and it is working fine https://www.armbian.com/armsom-sige5/
  2. The loop boot may be caused by not opening pd in the uboot stage. It has been fixed now https://github.com/armbian/build/commit/a46a7cfaf5216ac2dad33c5f129e7771e35d7c55
  3. sige7 and M7 are the same product, we use the same code After installing rmbian-firmware-full, the problem is still the same. https://paste.armbian.com/gusovosivi
  4. The ap6275p WiFi hotspot fails to open. The ap6275p itself supports the ap mode. image:Armbian_24.5.5_Bananapim7_bookworm_vendor_6.1.75_cinnamon_desktop.img sudo create_ap -m nat wlan0 enP2p33s0 armsom armsom-jack --no-virt --freq-band 5 Failed to get phy interface ERROR: Your adapter does not support AP (master) mode We used joshua-Riek/ubuntu-rockchip's ubuntu system which supports ap and has been connected normally
  5. ArmSoM-LM5 uses Rockchip RK3588, a new generation flagship eight-core 64-bit processor with a main frequency of up to 2.4GHz, a 6 TOPS computing power NPU, and can be equipped with a maximum of 32GB of large memory. It supports 8K video encoding and decoding and adopts LGA packaging, which has stronger transmission capability and stability. It has rich interfaces and supports multiple hard drives, Gigabit network, WiFi6, 5G/4G expansion and a variety of video input and output. Supports multiple operating systems; provides baseboard reference design materials, allowing users to customize in depth. Applicable to ARM PC, edge computing, cloud server, artificial intelligence, cloud computing, virtual/augmented reality, blockchain, smart NVR and other fields armbian github commit: https://github.com/armbian/build/pull/5854: wiki: http://wiki.armsom.org/index.php/ArmSoM-w3
  6. Please this Error context msg [ Check MD5 sum of installed packages failed ] what is the reason? https://paste.next.armbian.com/gigojaropu
