SergeiR
  1. Hi, I have a USB device that periodically hangs. Reboot or re-plug helps, but I need something lighter. I've seen several discussions on the problem of resurrecting hanging USB devices, but their solutions seems devices specific. Non on them worked in my case. I tried ioctl with USBDEVFS_RESET among other methods. uhubctl didn't work too (it seems it only sees EHCI hub, while my device is USB3.0 and connected to XHCI). Ideally the solution should depower a single USB connector to let the device fully reset and then get it connected back.
  2. Hey, Has anyone managed to capture image from this camera? `media-ctl -p` shows this device, that mentions the camera name: - entity 63: m00_b_imx415 3-001a (1 pad, 1 link) type V4L2 subdev subtype Sensor flags 0 device node name /dev/v4l-subdev2 pad0: Source [fmt:SGBRG10_1X10/3864x2192@10000/300000 field:none crop.bounds:(12,16)/3840x2160] -> "rockchip-csi2-dphy0":0 [ENABLED] But that's it. No luck with libcamera nor v4l2-ctl. The `rock-5ab-camera-imx415` layer enabled.
