lucat1
  1. I have purchased the following board, named H20 from AliExpress: https://it.aliexpress.com/item/1005005623753864.html I could boot the multitool for RK322x by holding the reset button, then selecting boot menu from Android's bootloader. After installing an armbian release, the board does no longer boot, and a red LED turns on immediately after giving power. I would like to try other Armbian images, but, I am no longer able to boot the multitool as I no longer have access to the Android bootloader, which I assume has been deleted by flashing the new ROM. Also, any attempt at booting the multitool on an SD card are failing. Does the SD card have priority over the EMMC on this model? Is there any way I can recover this board. I do not have a UART to usb dongle on hand, so I cannot provide you with any logs unfortunately. If there are any simple steps I could follow to bring the board back to life, and reattempt an install, please let me know. I would also like to point out that I can find the original ROM on xda, though I haven't tried it yet. I have left attached two pictures of the board, if they can be of any help.
