I've traced the problem back to a set-up that was working okay when I used the ASUS Debian O/S, but is now broken on Armbian.
My router is set up to assign 192.168.99.61 to the ethernet connection and 192.168.99.62 to the WIFI connection. The set-up that is now broken involved adding a virtual interface 40 seconds after each boot, to which the router assigns 192.168.99.64. The bash script setting up the virtual interface is as follows:
ip link add link eth0 address 22:05:19:61:00:00 eth0.1 type macvlan
ifconfig eth0.1 up
dhclient -v eth0.1
For testing purposes I disabled the bash script to set up the virtual interface. Then:
connected the ethernet cable while the board was running: SSH connections to both 192.168.99.61 and 192.168.99.62 worked fine ✔️
rebooted the board with the cable connected: again both connections worked fine ✔️
I then repeated the test with the bash script reenabled and a reboot:
connected the ethernet cable while the board was running: while the SSH connection over WIFI had been working, both SSH connections failed after connecting the cable ❌
rebooted: both SSH connections not working ❌
The network configuration with the virtual interface running, but before connecting the ethernet cable looks like this:
ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 0a:de:e9:d5:14:3c txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 74
eth0.1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 22:05:19:61:00:00 txqueuelen 1000 (Ethernet)
eth0.1:avahi: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 169.254.2.252 netmask 255.255.0.0 broadcast 169.254.255.255
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 1134 bytes 94702 (94.7 KB)
TX packets 1134 bytes 94702 (94.7 KB)
wlp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.99.62 netmask 255.255.255.0 broadcast 192.168.99.255
inet6 fe80::b9e2:65fb:f79b:299b prefixlen 64 scopeid 0x20<link>
ether 20:4e:f6:c1:c3:a9 txqueuelen 1000 (Ethernet)
RX packets 390291491 bytes 570483346160 (570.4 GB)
TX packets 24460636 bytes 3287101270 (3.2 GB)
I'm not sure why the virtual interface is causing this to happen. Myabe something to do with the Armbian O/S or maybe I should be setting it up another way?
